Right wheel wobble braking, grrrr, noise in wheel - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-12-2015, 01:17 AM Thread Starter
F250 6.0 2005.
My front wheel has a wobble when braking, and grrrr noise in wheel.. Now ac only blows from defrost. Could this be a bearing or something that may be causing a vacuum leak.. Thanks
Dukester1 is offline
post #2 of 9 (permalink) Old 02-12-2015, 01:44 AM
Re: Right wheel wobble braking, grrrr, noise in wheel
Hub, ball joints, brakes, etc. Time to start digging into the front end :)
2006 F350 4X4 CAB CHASSIS w/ Truck Bed
Blue Spring, Mishimoto tstat
Kdavid1 is offline
post #3 of 9 (permalink) Old 02-12-2015, 02:01 AM Thread Starter
is it possible for there to be a vacuum leak in the hub?
post #4 of 9 (permalink) Old 02-12-2015, 05:29 AM
Could be. Typically a bad hose. Don't think that would be your problem withe the shiimy and noise but anything is possible. Ive read some on the vaccum leals but haven't dealt with any myself.
Kdavid1 is offline
post #5 of 9 (permalink) Old 02-12-2015, 11:22 AM
mx185sw's Avatar
Wobble while breaking could be warped rotor (if your feeling it in the break pedal) or worn hub bearing or in addition worn front end parts (if your feeling it in the steering wheel) , the grrr noise is most likley hub bearing. Start with checking the front end parts, then move to 4wd vacumn issue (if replacing any worn parts doesnt correct the defroster issue).
Sean
___________________________________________
2005 F250 Harley CC SB Banks IQ, 4" Exhaust, Banks Techi Cooler with High Ram, Cold Air Intake, Cat Delete,EGR Delete,Coolant Filter,Amsoil Oil Filter Bypass, PHP ECM Rollback, PHP FICM Tuner, WW2,Rancho 9000XL shocks. Firestone Air Springs w/Daystar Cradles. 224K
mx185sw is offline
post #6 of 9 (permalink) Old 02-13-2015, 03:04 AM Thread Starter
Ok, just had a new hub assembly installed.. Took care of wobble and noise..
Vacumm pump must have run too long, it still comes on but can only feel a slight sucking from port. Pump keeps trying to run erratically when plugged up. Anyone recommend a place to get new one that's better or cheaper than dealer. Thanks
post #7 of 9 (permalink) Old 02-13-2015, 04:07 AM
I'd check the whole system for leaks first. From what I've read sometimes it easy and sometimes it hard to find the but I consider this along the lines of electrical trouble shooting and hate that as well lol
Kdavid1 is offline
post #8 of 9 (permalink) Old 02-13-2015, 11:03 AM
BigRed02
BigRed02's Avatar
The pump should run to satisfy the reservoir, so most likely a leak. I think the pumps are around $80 so make sure you really need one
2000 F350 CCLB 4x4 7.3L, 4R100, 6637, 4" MBRP turbo back
2000 F250 Red 4x4 Ext. Cab, 7.3L DI, ZF-6
2005 Ranger Dark Gray, FX4, 4 dr, 4.0 SOHC, 5r55e
2015 Ford Transit 3500, Dark Gray, HR EX, 3.5L ecoboost, 6 speed select shift
2011 Edge Limited Black, 3.5L
BigRed02 is offline
post #9 of 9 (permalink) Old 02-13-2015, 11:23 AM
mx185sw's Avatar
If after you check and confirm no leaks, you can pick up a pump from Amazon... i just replaced mine, and the new pump is extreamly quiet and a direct fit.. no complaints.
Sean
mx185sw is offline
