Coolant Leak. Replaced Water pump and T-Stat. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-11-2015, 11:21 PM Thread Starter
Midnight Murder
midnightmurder's Avatar
I have replaced my Degas bottle, my water pump, and my T-stat, but still manage to have a coolant leak. It runs under normal temps but will not hold coolant. It leaks heavily while running, and slightly when off. I am unsure as to where it is coming from. I had a T-stat leak but fixed that. (I already used the search function but cannot seem to find anyone else with this problem, if anyone else has this problem and created a thread. By all means show me) Any help would be greatly appreciated!
midnightmurder is offline
post #2 of 4 (permalink) Old 02-11-2015, 11:24 PM
whistle tits
ghohouston's Avatar
Re: Coolant Leak. Replaced Water pump and T-Stat.
Could be the donut gasket/fat o ring between intake manifold and front cover, could be front cover gasket, could be an o ring/gasket in the valley as well. You need to pressure test the coolant system.
ghohouston is offline
post #3 of 4 (permalink) Old 02-11-2015, 11:27 PM
Administrator
Zmann's Avatar
i suggest a pressure test and with the degas bottle and small 3/8 line it is an easy task to do
seems like you would have an idea of the proximity of the leak ??
now if it's head gaskets it will push coolant past the cap you can test for that easily also
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 4 (permalink) Old 02-11-2015, 11:31 PM Thread Starter
Midnight Murder
Thank you! I didn't even think of that! I will try a pressure test tomorrow when I'm off work! I'll post my findings!
