Fuel Pressure issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-11-2015, 03:33 PM Thread Starter
Fuel Pressure issue
I have a stock 2006, 6.0L. For the past couple months, I have noticed a lack in power and my fuel milage has gone in the toilet. I couldnt figure out what the problem was, so I finally took it in to my dealer. Got it back yesterday and was told that the fuel pump wasnt sending enough pressure and as a result, I now had 4 bad injectors. They replaced the pump and injectors. I picked up the truck yesterday and drove it home. For the first 40 or so miles, it ran great. Power was back, everything ran smooth, fuel mileage was back to where it should be. Then within a couple minutes, everything seemed to go back to where it was before I took it in. Truck ran rough, decrease in power... My fuel filter only has about 6000 miles on it, so it's not that....I'm wondering if the Fuel Pressure Regulator spring could be worn. Any ideas?
Kenny428 is offline
post #2 of 8 (permalink) Old 02-11-2015, 03:47 PM
matthewd11's Avatar
Re: Fuel Pressure issue
Check for codes. Does it smoke at all?? If you didnt do the blue spring kit yet ABSOLUTELY do it.
matthewd11 is offline
post #3 of 8 (permalink) Old 02-11-2015, 07:03 PM Thread Starter
No codes, no smoke. Just lacks power and runs a little rougher. To anyone else, it would probably seem fine but I know how it's supposed to feel and sound.
Kenny428 is offline
post #4 of 8 (permalink) Old 02-11-2015, 07:40 PM
blue spring mod if you dont already have it like mattewd11 said.
Check FICM
2003ford is offline
post #5 of 8 (permalink) Old 02-12-2015, 09:18 PM
are you monitoring pids? What is your FICM volts--low volts and will destroy FICM and injectors. Also clean ebp, iat, and maf.
2006 F350 4X4 CAB CHASSIS w/ Truck Bed
Blue Spring, Mishimoto tstat
Kdavid1 is offline
post #6 of 8 (permalink) Old 08-22-2015, 02:19 AM
NorCalJoe's Avatar
Location: Nor Cal away from cluster f--ks deep in the mountains
Good lord this sounds EXACTLY what my 6.0 is doing, BLUE SPRING...I hope.
NorCalJoe is offline
post #7 of 8 (permalink) Old 08-22-2015, 02:20 AM
NorCalJoe's Avatar
Did the Blue spring HELP??????
post #8 of 8 (permalink) Old 08-31-2015, 02:41 PM
Hard to believe the dealer didn't change the fuel filters when doing all that work. IMHO change the filters and do the blue spring conversion its a DIY job, I bought my kit from the international dealer at half the price of ford.
SeaDog is offline
