seatbelt dinger - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-10-2015, 07:29 PM Thread Starter
s10mike's Avatar
seatbelt dinger
How the hell do you turn that damn seatbelt finger off in a 2007 f350? It doesn't stop. Help!!!
s10mike is offline
post #2 of 7 (permalink) Old 02-10-2015, 08:35 PM
She's ALIVE AgAiN!!!
afFORDable's Avatar
Re: seatbelt dinger
JY a buckle and shove it in there and leave it. Problem solved for under $5.
04' (Late 03' engine) Lariat PSD, Auto, Crew cab, 4x4, high idle mod, egr delete, 6.4 banjo, blue spring, coolant filter, ARP studs, 21* HPOP, 6.4 starter, more to come.....
afFORDable is offline
post #3 of 7 (permalink) Old 02-10-2015, 08:46 PM
Ditch Digger's Avatar
Re: seatbelt dinger
I unplugged the wiring harness under the seat that goes to driver side buckle.
I wear my seatbelt but dont need it everytime the truck moves. It was aggravating!
2006 F450 13,000# Service Truck, Sct live wire /65hp tow tune. Baldwin BF1212 primary fuel/water seperator, Cat 1R-0750 secondary fuel, CAT ELC.
Ditch Digger is offline
post #4 of 7 (permalink) Old 02-10-2015, 08:52 PM
Re: seatbelt dinger
there is a "code" you can put in--consists of koeo and inserting and uninserting the buckle. There is a write up in another forum stickie on how to do it.
2006 F350 4X4 CAB CHASSIS w/ Truck Bed
Blue Spring, Mishimoto tstat
Kdavid1 is offline
post #5 of 7 (permalink) Old 02-11-2015, 02:18 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: seatbelt dinger
Usually just clicking my seatbelt in, then releasing will take care of it, but if it starts to chime again, repeat the process and it's good to go
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #6 of 7 (permalink) Old 02-11-2015, 02:58 AM Thread Starter
s10mike's Avatar
Re: seatbelt dinger
Thanks guys. I forgot about the click/unclick code, its been a long time since I did my truck.
s10mike is offline
post #7 of 7 (permalink) Old 02-11-2015, 03:04 AM
Re: seatbelt dinger
I still haven't done mine-but need too.
I can usually get by if I take the seat belt off after I've gone about 100ft.
it does suck when at the boat ramp and thst thing is dinging away lol.
Kdavid1 is offline
