06 Powerstroke Water Leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 02-10-2015, 02:13 AM Thread Starter
I have a 06 F350 Powerstroke that I purchased new. I have a very stlight water leak that leaves a small puddle under the truck and best I can tell is dripping from the passenger side rear corner of the oil pan. Also I see droplets on the starter. It has head studs that were installed at around 40k miles. It now has 113k miles. I had a egr delete installed the summer of 2014. Before installing the egr delete, it would puke slightly under heavy loads. Since installing the egr delete I have not seen it puke any fluids. But now, I have the external leak near the rear of the engine. I have looked at the valley of the block and see no water up top. It will lose about a quart every two weeks. Thanks for any help!
brinson is offline
post #2 of 10 (permalink) Old 02-10-2015, 02:30 AM
JGman141
Jgman141's Avatar
Re: 06 Powerstroke Water Leak
Egr coolant hose could be leaking
Jgman141 is offline
post #3 of 10 (permalink) Old 02-10-2015, 02:47 AM Thread Starter
Is that the hose that attaches to the U shaped egr tube?
brinson is offline
post #4 of 10 (permalink) Old 02-10-2015, 02:51 AM
JGman141
Jgman141's Avatar
Yes
Jgman141 is offline
post #5 of 10 (permalink) Old 02-10-2015, 03:02 AM Thread Starter
As best I can see, I don't see any water around this hose or in the valley. Of course it's pretty hard to see through all the stuff in the way.
brinson is offline
post #6 of 10 (permalink) Old 02-10-2015, 03:17 AM
Tom's 2006 F250's Avatar
Have you checked the vacuum valve for the heater that is near the rear passenger side of the vehicle? It controls the flow of coolant to the heater core.
EGR delete
SCT tuner
Coolant bypass filter
4.5" Rough Country lift kit with 35x12.50x18" tires
Blue fuel regulator spring
(2) 12" Pioneer subs with 1200 Watt Pyle amp
Tom's 2006 F250 is offline
post #7 of 10 (permalink) Old 02-10-2015, 03:27 AM Thread Starter
I have run my hand under it and saw no water.
brinson is offline
post #8 of 10 (permalink) Old 02-10-2015, 11:58 AM Thread Starter
Can a cyl. gasket leak externally?
brinson is offline
post #9 of 10 (permalink) Old 02-10-2015, 01:19 PM
matthewd11's Avatar
Check J tube/hose for EGR delete and heater control valve.
matthewd11 is offline
post #10 of 10 (permalink) Old 02-10-2015, 10:38 PM Thread Starter
Both the J tube hose and heater control valve do not seem to be leaking.
brinson is offline
