HPOP....Is it normal? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 02-08-2015, 11:06 PM Thread Starter
She's ALIVE AgAiN!!!
afFORDable's Avatar
Just needing advice.
I air tested my HPOP and oil rails from the "J" Tube on top of the HPOP. Heard air leaking from what seemed to be under the HPOP.
Took the HPOP out and plugged the bottom hole and pushed air through the top hole, where the "J" tube connected, and it blew oil from behind the gear that sits on the flywheel.
Is this normal or is the seal blown? Whats up here?
Replacement?
04' (Late 03' engine) Lariat PSD, Auto, Crew cab, 4x4, high idle mod, egr delete, 6.4 banjo, blue spring, coolant filter, ARP studs, 21* HPOP, 6.4 starter, more to come.....
afFORDable is offline
post #2 of 24 (permalink) Old 02-09-2015, 12:59 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: HPOP....Is it normal?
You talking about around the main shaft that come out of the pump?
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #3 of 24 (permalink) Old 02-09-2015, 02:03 AM Thread Starter
afFORDable's Avatar
Yes. She blew oil from there. And it didn't seem to me to be just a little bit.
post #4 of 24 (permalink) Old 02-09-2015, 03:29 AM
Big dumb redneck
6speedSD's Avatar
Garage
Yea, I was going to say I've heard a little is ok. Just not sure what "a little" really amounts to.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #5 of 24 (permalink) Old 02-09-2015, 04:33 PM Thread Starter
afFORDable's Avatar
Os there a way to rebuild this thing or am I better off buying a reman?
post #6 of 24 (permalink) Old 02-09-2015, 05:52 PM
What problem are you chasing down?
post #7 of 24 (permalink) Old 02-09-2015, 09:31 PM Thread Starter
afFORDable's Avatar
No start.
Couldn't get air test past the HPOP. Blowing out of the main shaft.
Been working on this thing for a year.
post #8 of 24 (permalink) Old 02-10-2015, 01:56 PM
No start... Hot or cold or both?
post #9 of 24 (permalink) Old 02-10-2015, 02:02 PM Thread Starter
afFORDable's Avatar
Both. Last year I completed a head gasket/ARP stud install amongst other upgrades while I was in there. Truck ran like trash for about half a day and I ended up having to tow it home. Dug back in to try and find the problem. Then other things got in the way, financially. I finally got back to it this weekend and air tested through the "J" tube on top of the HPOP and heard a leak from behind. I pulled the HPOP and dead headed it with the bottom hole plugged and found, what I considered to be, a large amount of blow by coming from the main shaft seal. I am in the process of getting the funds to replace the HPOP but that's where I stand at the moment. I will try to plug the "J" tube this weekend and see if I cant find leaks elsewhere but Im thinking that the blow by in the HPOP is most likely where my issue lies.
Down side is that the truck has been sitting for a year. Im certain the coolant and oil need changed as well as the fuel being gelled by this point.
post #10 of 24 (permalink) Old 02-10-2015, 07:15 PM Thread Starter
afFORDable's Avatar
OK, well, if no new information comes through in the next few days, I suppose Ill throw an HPOP at it and go from there.
Thanks for the info guys.
