6.0 up pipes? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 02-07-2015, 01:21 AM Thread Starter
samtheman524's Avatar
6.0 up pipes?
Hi I bought a 05 F-350 for 3500 not running. I put new batteries and a new fuel pump in had she started right up. But it feels pretty low on power, there is a pretty loud hiss coming from the right side of the engine, and there is some black smoke when accelerating. I was pretty sure it's the up pipes but I wanted to make sure before I buy new ones.
99 F-250: aFe intake, TS-6pos chip, and MBRP 4" turbo back straight pipe.
samtheman524 is offline
post #2 of 15 (permalink) Old 02-07-2015, 01:40 AM
matthewd11's Avatar
Re: 6.0 up pipes?
probably up pipes but i'd get underneath and stick your hand by the bellows to see if you feel air coming out. could also be turbo collector.
matthewd11 is offline
post #3 of 15 (permalink) Old 02-07-2015, 01:52 AM Thread Starter
Re: 6.0 up pipes?
Ok thanks I'll check that.
post #4 of 15 (permalink) Old 02-08-2015, 12:18 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: 6.0 up pipes?
Feel around them like mentioned....cold engine. Should come out with soot in your hand if it's leaking.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #5 of 15 (permalink) Old 02-08-2015, 02:32 AM Thread Starter
Re: 6.0 up pipes?
I can't run it because I pulled the fuel bowl but I looked around the up pipes and there is black soot on the down pipe where the flex pipe is.
post #6 of 15 (permalink) Old 02-08-2015, 02:34 AM
JGman141
Jgman141's Avatar
Re: 6.0 up pipes?
I'd say that they are blown then, Nate at WPE makes a nice set of pipes
Jgman141 is offline
post #7 of 15 (permalink) Old 02-08-2015, 03:12 AM Thread Starter
Re: 6.0 up pipes?
Ok thanks.
post #8 of 15 (permalink) Old 02-08-2015, 03:51 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: 6.0 up pipes?
Have a set of his on mine. Quality work.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #9 of 15 (permalink) Old 02-08-2015, 07:05 PM
She's ALIVE AgAiN!!!
afFORDable's Avatar
Re: 6.0 up pipes?
I have 2 extra sets of NEW open box OEM stand pipes for late 04+ if youre interested.
Still in bags/boxes.
04' (Late 03' engine) Lariat PSD, Auto, Crew cab, 4x4, high idle mod, egr delete, 6.4 banjo, blue spring, coolant filter, ARP studs, 21* HPOP, 6.4 starter, more to come.....
afFORDable is offline
post #10 of 15 (permalink) Old 02-08-2015, 08:46 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: 6.0 up pipes?
What does this have to do with up-pipes?
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
