2005 6.0 stutter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 02-06-2015, 01:51 AM Thread Starter
NYFB. Thats what.
jontheturboguy's Avatar
2005 6.0 stutter
Im 99% sure this is a stiction issue, but here's the story.
2005 f250
6.0
Blue spring upgrade
Egr delete
5" exhaust
Aftermarket air intake
sct tunes
Typical 6.0 cold start rattle / cold hesitation / cold stutter until the truck is warmed up.
Had 60hp SCT tow tune on it, and truck would stutter in the higher rpm range under WOT.
New Motorcraft filters, 10w30, fresh fuel, hotshots secret fuel & oil additives.
Truck starts better. Fuel economy is lightyears ahead of where we were at. Truck still stutters under WOT on top end.
So, I removed the sct tunes and back to stock.
Here's where Im confused.
The truck runs worse now. Stutters through out the rpm band. Warm, cold...doesn't matter.
Ideas?
The mods are dumb for posting in my Sig line. Next time the mods are gonna ban me and be down to a whopping 10 members. I love PSN!!
jontheturboguy is offline
post #2 of 16 (permalink) Old 02-06-2015, 02:03 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: 2005 6.0 stutter
Yep, your right it's most likely a injector issue.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #3 of 16 (permalink) Old 02-06-2015, 03:35 PM
Wheelhop's Avatar
I agree with Gary, it sounds like an injector problem. You might also try cleaning the EBP tube. Mine had a stutter on the top end when it was gummed up.
Wheelhop is offline
post #4 of 16 (permalink) Old 02-06-2015, 06:18 PM
Big dumb redneck
6speedSD's Avatar
Garage
Checked your FP lately? Pressure drops at wot with stock pumps....if your fuel pressure is low to start with, or you have a weak pump, it'll starve for fuel at wot. Just an idea...
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #5 of 16 (permalink) Old 02-06-2015, 07:58 PM Thread Starter
NYFB. Thats what.
Absolutely. Equipment to test should be here Monday. Hence why I pulled the SCT tunes thinking maybe stock would have less of a fuel demand?
post #6 of 16 (permalink) Old 02-06-2015, 09:46 PM
Big dumb redneck
6speedSD's Avatar
Garage
Good deal. I'm sure you already know, but if it is stiction, a 5w oil will make it much happier than that 10w30. I tried 10w30 in mine before I had the injectors rebuilt. Truck did NOT like that stuff!
Ever find a set of heads like you were looking for?
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #7 of 16 (permalink) Old 02-12-2015, 01:40 AM Thread Starter
NYFB. Thats what.
Nope. Still looking for a set of heads. Had the truck scanned tonight. All parameters check out aok. 48v ficm, ok ipr, etc etc.
So we check fuel pressure next.
post #8 of 16 (permalink) Old 02-12-2015, 02:13 AM Thread Starter
NYFB. Thats what.
Something I want to add to ask opinion on...
Even after driving around volts only measure 13.2 to 13.3.
And, no matter how long or hard you run the truck the hottest it will get is 178 deg. Is this bad?
post #9 of 16 (permalink) Old 02-12-2015, 05:25 AM
Ti e for a new tstat for one.
on the volts--you probably need to load test your batteries and possibly replave both.
would b3 good to load test the alt too. I assume you have a dtocl alt?
2006 F350 4X4 CAB CHASSIS w/ Truck Bed
Blue Spring, Mishimoto tstat
Kdavid1 is offline
post #10 of 16 (permalink) Old 02-12-2015, 03:13 PM
Big dumb redneck
6speedSD's Avatar
Garage
Did you get the pm i sent a while back about the set of heads i have? If you don't want them its cool, just making sure you got the pm
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
