rear whine - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 02-05-2015, 10:24 PM Thread Starter
rear whine
2006 F450 4x4 crew cab 201"
the rear has had a small whine since new but just thought it was normal
then at 45,000 miles dealer said sounds bad and probably pinion wearing out
they said $5000 to fix with no guarantee on noise
now that I have 122,000 miles it is terrible
hurts your ears at certain speeds but drives fine
Dealer said last week that it will need to be replaced soon
Anybody have thoughts or insite
I live Outside of Baltimore near Bel Air, MD
anybody know a shop that can fix this?
evaconstruction is offline
post #2 of 16 (permalink) Old 02-06-2015, 02:28 AM
Re: rear whine
IMHO, most Ford dealers don't have a clue how to properly set up a rear end. My advice is to find a ring and pinion shop. A reputable one.
Now be forewarned, I believe some center sections aren't machined 100% correctly. My race car has been set up by two different shops three times and twice by me. None have been quite. Either bad luck of the draw, or something isn't right to begin with. However, that said, that's a Mustang with a substantial amount of the interior and insulation gone. Any noise will be audible. In order to hear a rear end noise on a truck it has to be pretty darn loud.
post #3 of 16 (permalink) Old 02-06-2015, 04:29 AM
1sd
1sd's Avatar
Re: rear whine
Sounds like ring and pinion to me too. But $5000 to fix it??? What the h***? Don't EVEN pay that kind of money to have a R&P replaced. Look around for a local driveline shop or even an off road shop. I re-geared my '06 when it was new to compensate for the tires. I don't remember exactly what I paid to have the front AND rear done but I think it was a little over $1000...MAYBE.
Steel Gray, 2006 SD CC, XLT Lariat, 8" Fabtec lift on 37/14.50x20 Falken Wild Peaks. 20x10.5 Moto Metals. Quad Fox Shox Reservior on all corner, 4.56 ring and pinions, Baja Designs 8" Sol Tec lights, Amp Research electric steps. Kenwood head unit, Yeasu FT8800 tri-band ham, Lowrance Elite 5M GPS. Snug Lid bed cover with Bed Rug liner.
1sd is offline
post #4 of 16 (permalink) Old 02-06-2015, 06:22 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: rear whine
Another stealership fail. $5k for that job is just robbery. Are they replacing the entire axle with one made of platinum or gold?
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #5 of 16 (permalink) Old 02-06-2015, 10:21 PM
Re: rear whine
My only whinning comes from the passengers seats.
lenzhotrod is offline
post #6 of 16 (permalink) Old 02-06-2015, 11:47 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: rear whine
This times 10billion!
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #7 of 16 (permalink) Old 02-07-2015, 07:11 PM Thread Starter
Re: rear whine
this truck has had every problem a 6.0 can have as well as other stupid issues
bleeding hundred dollar bills by the handful and sitting in the shop for 34 major mechanical issues since new
I will have to look around town as at this point the truck has turned into a "HUGE" investment just to use for work
Thanks for the replies
post #8 of 16 (permalink) Old 02-08-2015, 12:14 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: rear whine
34 major issues? Either you bought the worst 6.0 ever, or you are hell on a vehicle....
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #9 of 16 (permalink) Old 02-08-2015, 03:56 AM
96powerstroker's Avatar
Re: rear whine
34 issues. Like what? Im curious. If I had half that number I would have give it a new home
96 F250 2WD, 286K, Built E4OD, 180cc Injectors, Tony Wildman Tunes, Beans Fuel System, 3in DP - 4in MRBP exhaust, CAI, 4:10LS SCLB, Traction bars,
62 F250 4X4, 223 I6, T98 4 speed, 4:56s RCFS (Reg Cab Flare Side. Factory) 31x10.50x15s, currently on 16in Alcoas
96powerstroker is offline
post #10 of 16 (permalink) Old 02-10-2015, 03:20 AM
My other twin turbo...
eleventhtruck's Avatar
Re: rear whine
Most likely just the pinion bearings I would think. Check the dif for abnormal gear wear to verify.
eleventhtruck is offline
