IPR screen trashed with gasket/Oring material - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 02-04-2015, 12:23 PM Thread Starter
Ditch Digger's Avatar
New ford oil cooler and gaskets 40k miles ago for preventive maintenance. 225,000 on truck now
2 starts then died on cold mornings (25 degrees) in last 4k miles. First time replaced IPR this time cleaned IPR and replaced screen. Screen trashed both times.
No problems warm starts so not thinking its orings from high pressure rails or injectors..... Any ideas where material would be coming from?? Thanks
2006 F450 13,000# Service Truck, Sct live wire /65hp tow tune. Baldwin BF1212 primary fuel/water seperator, Cat 1R-0750 secondary fuel, CAT ELC.
Ditch Digger is offline
post #2 of 16 (permalink) Old 02-04-2015, 06:58 PM
Re: IPR screen trashed with gasket/Oring material
That green doesn't look like ford OEM--are you sure it was OEM? What your pic shows looks like trashed dorman gasket material. I bet the hpop screen is covered in that mess.
2006 F350 4X4 CAB CHASSIS w/ Truck Bed
Blue Spring, Mishimoto tstat
Kdavid1 is offline
post #3 of 16 (permalink) Old 02-04-2015, 08:33 PM Thread Starter
Feel confident it was a ford oil cooler, a ford tech put it in and preached to only use genuine ford. The oil I use is rich blue in color and possibly stained the pieces bluish/green. I just picked new oil cooler up from dealer and next plan of attack is to put it in and see what screen looks like. Thanks for your reply! I am welcome to any input.
post #4 of 16 (permalink) Old 02-04-2015, 08:38 PM
Good deal. I can't say as I've ever seen or heard of the oem gaskets doing that but anything is possible. It would be interesting to know what Ford would have to say about it--maybe you cold get some kind of comp on it--you never know. Least it's not too bad of a job to fix.
Kdavid1 is offline
post #5 of 16 (permalink) Old 02-05-2015, 11:34 AM Thread Starter
Attached another pict to help anyone having same issue. I agree on anything is possible. Could be oem gaskets failing. I have had a slight oil leak after the oil cooler was installed that has gotten worse. I will repost after I break it down and have more info. Might invest in heavy duty hpop screen from IPR research if others have had good results with it. Keep yall posted
post #6 of 16 (permalink) Old 02-05-2015, 12:13 PM
when you replace a oil cooler you are suppose to clean very good and blow air around the oil cooler before and after the removal of oil cooler . When I did my oil cooler I cleaned very good and my IPr screen still got dirty and truck was dieing out. Dirt could be coming from the oil cooler change. You might have to clean the ipr screen a few times to get it right and pray nothing got in to damage the oil pump.
cas15 is offline
post #7 of 16 (permalink) Old 02-06-2015, 01:16 PM Thread Starter
I hear ya on keeping it clean.. We tried hard to be very clean but i had same issue right after oil cooler install. Had grit in the screen that time. It has been good for about 40k miles. Then started having problems again but with the gasket looking material not sand/grit debris. I will update after I get inside to see whats happening. Thanks
post #8 of 16 (permalink) Old 02-06-2015, 06:19 PM
Big dumb redneck
6speedSD's Avatar
Garage
Would be some chit if dealer cheaper out and slapped a Dorman cooler in the thing....
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #9 of 16 (permalink) Old 02-08-2015, 12:50 PM Thread Starter
Uggg . That would hurt my feelings! Once I get the oil cooler out I should be able to tell if its got a ford part number on it? I think I read Dorman puts there name or trademark on theirs. Dorman supplied gaskets would be the culprit if thats the case.
post #10 of 16 (permalink) Old 03-22-2015, 02:56 AM Thread Starter
Broke her down today..... Dorman is the problem. kdavid1 called it. Putting new oem cooler in now
