2005 6.0 30psi and goes down to 25 on w.o.t - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-03-2015, 10:51 PM Thread Starter
fukenricen's Avatar
Hi everyone i havte a 2005 f250 6.0
i noticed i been having issues with the truck when i hit the track and started going from a 14.3 to a 14.8 and lower mph.
before i had the studs gasket,egr delete ,new hpop,new injectors ect the truck would hit 30psi under a gearhead tune
now the truck hits 30psi if i am 3/4 throttle on the highway but as soon as i hit the throttle all the way down the boost drops to 20-25 and stays there.
at first i though i thought i had a boost leak but the pipes seem fine and the boost is holding firm at 20-25psi
please help i have asked all around and no one has an answer for me ,
is this a common issue if the turbo needs cleaning or replacing?
thanks
2005 f250 harley,35"nitto's,
sct [email protected] tune
fukenricen.ca
fukenricen is offline
post #2 of 6 (permalink) Old 02-04-2015, 05:15 PM
matthewd11's Avatar
Re: 2005 6.0 30psi and goes down to 25 on w.o.t
sounds like its just the VGT going to full open at WOT. Sounds normal to me. If you think you still have low boost, triple check up pipe bellows for leaks, as well as charge pipes. Check map sensor port in intake and the line that goes to the sensor as well.
matthewd11 is offline
post #3 of 6 (permalink) Old 02-05-2015, 01:00 AM Thread Starter
fukenricen's Avatar
will do thanks , vgt going to full open at wot normal?
fukenricen.ca
post #4 of 6 (permalink) Old 02-05-2015, 01:58 PM
matthewd11's Avatar
Yes, you dont want the turbo to restrict airflow at WOT, so it opens them to allow maximum air flow. At part throttle they are closed (variably controlled by VGT solenoid) to allow higher boost at part throttle. That is the nice thing about VGT.
post #5 of 6 (permalink) Old 02-05-2015, 02:06 PM Thread Starter
fukenricen's Avatar
thanks for the info , i guess i shouldnt worry about the turbo but either way i will open her up and see if it needs cleaning
fukenricen.ca
post #6 of 6 (permalink) Old 02-13-2015, 10:44 PM
I Just Break Stuff
Hmmmm..... or you have an up pipe leaking..... I would check it out if boost starts gradually fading off...
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
