Powerstroke 6.0 Starts, Runs, Then starts missing and then DIES!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 04-30-2014, 12:49 AM Thread Starter
6.0 Headache
Hi Everybody
Im at a loss with figuring this out. My Truck will start up run perfect then it starts misfiring and then it get so bad and stall out. Sometimes white smoke sometime it doesn't. It does smell like raw diesel.
Now i have deleted the EGR. No coolant loss.
Fuel Pressure is holding 58PSI when is does stall.
The IPR is like 32% if i remember Correctly.
The ICP is reading normal. It goes up to about 900-1000 PSI when it stalls.
The Ficm Is 48V all through out.
I have done the bulletproofing myself. I did the HPOP and HPO Branch Tubes.
Also i get one code. P0269 - Cylinder 3 Contribution/Balance
But if i shut down that injector it does run different so i no the injector is working. I Hooked up a snap on modis and did a buzz test and it all checks out.
The only thing i can think of is Injectors But im not someone to throw parts at it and find out its not it.
Please any/suggestions are welcomed.
I really need Help with this thing.
Druffing is offline
post #2 of 9 (permalink) Old 04-30-2014, 01:23 AM
Re: Powerstroke 6.0 Starts, Runs, Then starts missing and then DIES!!!
having similar problem. i did a cylinder contribution test. cylinders 1,3,5,7 not working miss-firing. from what i know we both have to have a high pressure oil system problem. sorry to post no advice.
stroking350 is offline
post #3 of 9 (permalink) Old 04-30-2014, 03:14 AM
Big dumb redneck
6speedSD's Avatar
Garage
1,3,5, and 7 are on the same plug on FICM. I'd start there before I began replacing injectors. Not plugged in well, loose connection, etc...
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #4 of 9 (permalink) Old 04-30-2014, 03:57 AM
bluesbish's Avatar
one of your injectors is loose pushing combustion gas back into the fuel system and causing an air lock. probably #3.
bluesbish is offline
post #5 of 9 (permalink) Old 04-30-2014, 06:50 AM
Fixing Broken Stuff
toolmangary's Avatar
^^^ Yep, that's what I'd look for first.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #6 of 9 (permalink) Old 04-30-2014, 02:57 PM Thread Starter
6.0 Headache
My HPO system is good. Ficm is good. I just down injectors and they all make a difference. Im gonna do the rubber glove test on the fuel lines today. I think I blew a copper washer out on the injector that's the only logical thing I can think of.
Druffing is offline
post #7 of 9 (permalink) Old 05-01-2014, 12:13 AM
bluesbish's Avatar
wow...good thinking!
post #8 of 9 (permalink) Old 05-01-2014, 02:07 AM
whistle tits
ghohouston's Avatar
Injector could be hanging open too
ghohouston is offline
post #9 of 9 (permalink) Old 05-02-2014, 01:17 AM Thread Starter
6.0 Headache
Turns out that cooper washer was done. New washer and seals and truck is running perfect.
Druffing is offline
