Intermittent A/C cold air problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-29-2014, 02:24 PM Thread Starter
I am having a problem with my A/C in my 05 6.0 CCLB DRW F350. My A/C will cycle between cold air and hot air. Can someone help??
Thanks
Antiquefloorman is offline
post #2 of 6 (permalink) Old 04-29-2014, 03:48 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Intermittent A/C cold air problem
Blend door? Is the vacuum line still hooked up to the climate control valve in your heater hose under the hood? Right above the passengers valve cover.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #3 of 6 (permalink) Old 04-29-2014, 06:57 PM
Check the air gap between your clutch & the hub. If it is too large the clutch won't engage when needed. There are shims between them that you can take out to get the gap to specs. Mine did this last summer. Diagnoses was new compressor. Saved me some $. Worth checking into. Easy fix if that is your problem. If that's not it check your freon.
2006 F350 4X4 Lariat
Edge CTS
Dieslsite coolant filter
Blue spring update
Updated STC HPOP Fitting
SCT Tuner w/ Matt's tunes
Atlas 40 FICM tune from Ed
178,000 miles
Tinbender is offline
post #4 of 6 (permalink) Old 04-29-2014, 09:13 PM
NDPSD's Avatar
I have the same issue, seems the general consensus is the air gap. Is shimming it a long term fix, or temporary solution?
NDPSD is offline
post #5 of 6 (permalink) Old 04-30-2014, 01:46 PM
It is long term. Your taking a shim out. The clutch is like a clutch on a transmission. It wears and you have to make that adjustment to make it work properly. The shims are there for that purpose. Most shops will diagnose new compressor and sometimes this is the fix. IIRC the gap needs to be around .03. Mine was at .08 and took out an .056 shim and that took care of the problem.
Edge CTS
Blue spring update
178,000 miles
post #6 of 6 (permalink) Old 04-30-2014, 05:50 PM
NDPSD's Avatar
Sounds like something to try anyway, thanks for the info i hate being without a/c!
NDPSD is offline
