truck vibration - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 04-28-2014, 12:02 PM Thread Starter
truck vibration
Just installed a set of Warren Injectors and the 6.4 banjo bolts truck cranks great and runs ok, but when driving and truck rpm starts getting around 12-1400 rpm it starts like a gas engine with a plug wire off. Any suggestions FICM voltage is 47.5-48.0 fuel pressure stays at 65-70 lb all looks find from edge cts.
buckshot63 is offline
post #2 of 9 (permalink) Old 04-28-2014, 02:44 PM
06-6.0 stoker's Avatar
Re: truck vibration
How many miles have you driven since the install? Have you run wot? Air needs to be out of the system
Sent from AutoGuide.com App
2006 f250 4x4 6in lift 37x13.5 tires
A few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #3 of 9 (permalink) Old 04-29-2014, 02:10 PM Thread Starter
Re: truck vibration
Ran app 150 miles and yes i have ran WOT still getting alot of vibration mostly when goes in OD
post #4 of 9 (permalink) Old 04-29-2014, 03:37 PM
Banned
Re: truck vibration
What size injectors? Do you have anything to pull codes off of the computer? Or to monitor engine data? Watch ICP desired, actual, ICP voltage and IPR duty cycle.
sixohdieselrage is offline
post #5 of 9 (permalink) Old 04-30-2014, 12:40 PM Thread Starter
Re: truck vibration
155/30 yes have the edge cts icp voltage is around 0.9-1.5 did notice that just for a little while got to 3.0 and higher but only did for a few seconds then went back to normall
post #6 of 9 (permalink) Old 04-30-2014, 02:33 PM
Banned
Re: truck vibration
Get us vehicle speed, RPM, ICP voltage, IPR duty cycle, FICM voltages and VGT duty cycle, when it starts doing doing that.
post #7 of 9 (permalink) Old 04-30-2014, 11:53 PM
Re: truck vibration
Did you clean the injector sleeves and mounting holes? May have a loose injector.
lenzhotrod is offline
post #8 of 9 (permalink) Old 05-01-2014, 02:57 PM Thread Starter
Re: truck vibration
I didn't clean sleeves or mounting holes on this I guess never really thought about that but to late now.
It only vibrates around 12-1600 rpm after passes 2000 rpm clears right up and runs smooth
post #9 of 9 (permalink) Old 05-03-2014, 01:53 AM
Re: truck vibration
The problem will not get better on its own. Could get a lot worse and do some real damage.
