Possible Tranny Problem?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 04-27-2014, 07:51 PM Thread Starter
So my dad has a 2004 Ford F-350 6.0L that only has 80 thousand miles on it. Its a very very nice truck. About 3 months ago he lost an injector so he had the whole one side done with injectors due to financial problems. Anyways now when we are driving around and the truck shifts into overdrive. If you push the pedal decently hard in overdrive it was make the whole truck vibrate really bad. But then when it shifts down then it has no problem. What do you guys think this could be?? Tranny related?? Maybe a sensor. I'm not very familiar to 6.0's being I have a 1996 7.3l. Any help would be very appreciated!!
Powerstroker88 is offline
post #2 of 14 (permalink) Old 04-27-2014, 11:41 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Possible Tranny Problem??
Codes...need to scan it for codes. If an injector is misfiring, it'll cause this exact same issue to happen. Not saying that's the case, but without getting it scanned, it's just a guessing game.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #3 of 14 (permalink) Old 04-27-2014, 11:43 PM
Banned
tcc shudder???
On the fords I have had some good luck with a product from Dr Tranny called shudder fix.
It is easy to use. And will not have any bad side effects.
jkholder09 is offline
post #4 of 14 (permalink) Old 04-28-2014, 02:28 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Don't put shudder fix in this trans! It will have bad effects on the solenoids, and it won't fix your problem. This trans DOES NOT have a problem with converter shudder. Your shudder problem is one or more injectors, it is not in the transmission.
Mark
Mark Kovalsky is offline
post #5 of 14 (permalink) Old 04-29-2014, 01:53 AM
dmoser27's Avatar
Having the same exact issue in f550 bucket truck, interested in what you find. Keep us posted
dmoser27 is offline
post #6 of 14 (permalink) Old 04-29-2014, 02:39 AM
cook03F250's Avatar
No idea but interested in what it may be...
cook03F250 is offline
post #7 of 14 (permalink) Old 05-01-2014, 03:36 AM Thread Starter
K will do. Its going into the shop next wednesday so we will see what happens. Thanks guys!!!!
post #8 of 14 (permalink) Old 05-08-2014, 12:47 AM
dmoser27's Avatar
Any update on the issue?
dmoser27 is offline
post #9 of 14 (permalink) Old 05-10-2014, 01:21 AM Thread Starter
Its supposed to be done today but we havent gotten a call so not a clue yet. They say that the 5th injector was bad. It was bad before so we replaced it. Which is weird because this injector failed in less then 6 months.
post #10 of 14 (permalink) Old 05-11-2014, 11:25 PM
dmoser27's Avatar
just don't understand why we only feel it in overdrive? you would think an injector would rear its head no matter the gear...
dmoser27 is offline
