6.0 Not charging... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 04-27-2014, 02:50 PM Thread Starter
Boost Junkie
6.0&SN95tagteam's Avatar
6.0 Not charging...
Long story short, noticed that the alternator was going bad, so changed the alternator, which worked for a couple of days. Now the charging system light on the dash comes on a couple of minutes after the truck is on.
Post on the alternator shows ~15v KOEO
Both batteries show ~15v KOEO
Both pigtail pins show ~15v KOEO
Monitor shows ~11-12v KOEO
Continuity between alternator and positive battery posts is good, as is ground posts and the chassis
any ideas? because I'm about to light it on fire...
2004 F250 CC 6.0 4x4
Intake, RCD 190cc/100 sticks, RR, 4 in turbo back, deleted, studded, SRL+ by Matt @ Gearhead, blah blah blah
6.0&SN95tagteam is offline
post #2 of 17 (permalink) Old 04-27-2014, 03:27 PM Thread Starter
Boost Junkie
Re: 6.0 Not charging...
Also should probably note that all voltages were taken after the glow plugs shut off...
post #3 of 17 (permalink) Old 04-27-2014, 07:22 PM
Administrator
Zmann's Avatar
the light can be low charge or overcharge 15 volts is high are you sure ?
also I think We talked about parts house rebuilt alternator quality before ?
if not they are notorious for not working on a60 superduty properly
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 17 (permalink) Old 04-27-2014, 07:42 PM Thread Starter
Boost Junkie
yeah, checked it over two days with a DMM. Given the fact that the monitor is still shoing ~11-12 and the batteries aren't charging for anything is what's giving me fits
post #5 of 17 (permalink) Old 04-27-2014, 07:47 PM
"Slap hands slap hands"
FlossyB's Avatar
sounds like you might have got a bad alternator has the truck died or had any issues or just the light coming on?
JB
FlossyB is offline
post #6 of 17 (permalink) Old 04-27-2014, 07:54 PM Thread Starter
Boost Junkie
No, the truck hasn't died yet, but I'm hesitant to drive it real far in case it decides to let go...
But like I stated earlier, it's not charging either
post #7 of 17 (permalink) Old 04-27-2014, 09:24 PM
Administrator
Zmann's Avatar
i'm just going to say there is no way IMHO your batts are 15 volts key on engine off
if the alternator has not been charging them for even 1 glow plug cycle / start/ run
but u would want to throw a known good DVM on the output post of the alt when starting and running to see what it's doing and really verify it's the Alt and not a connection
monitors tend to read lower than the actual output from what I have seen
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 17 (permalink) Old 04-27-2014, 10:58 PM Thread Starter
Boost Junkie
Post on the alternator shows ~15v KOER
Both batteries show ~15v KOER
Both pigtail pins show ~15v KOER
Monitor shows ~11-12v KOER
EDIT: fixed
Ah, ZMann, you sir would be correct, engine is running, not off, so KOER?
post #9 of 17 (permalink) Old 04-27-2014, 11:01 PM
Sounds like your regualtor in your alternator is bad, you need a new alternator... a good quality one
one day...
2006 silver f350 crew cab
5i1v3rback02 is offline
post #10 of 17 (permalink) Old 04-28-2014, 12:40 AM
Administrator
Zmann's Avatar
yes KOER = Key On Engine Running KOEO Engine Off
your battery light may be over voltage I can't remember the threshold for that off hand
DTR's Donation page
RIP DTR Ron
Zmann is offline
