Bad vgt solenoid??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-26-2014, 09:24 PM Thread Starter
zaner's Avatar
Bad vgt solenoid???
Could a malfunctioning vgt solenoid be dumping oil into the turbine housing?
Vgtdc is stuck at 14% at all times, no boost no power and oil dripping from turbine/downpipe coupling
2004 harley davidson f250 10" lift 40" mud grapplers, home made fuel system/rr, 205/100s, kc 68mm, TSD SPD tune
zaner is offline
post #2 of 3 (permalink) Old 04-27-2014, 01:06 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Bad vgt solenoid???
Sounds like your seals are shot. Not sure why the solenoid would be stuck on 14% though.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #3 of 3 (permalink) Old 04-27-2014, 02:22 PM
spence_08's Avatar
the ring in the turbo could be stuck and yes your seals are probably gone
08 superduty 6.4 fx4 sct live wire 9625or edge evo monitor flow pro 5 inch downpipe back. Afe stage 2 cold air intake 35 inch mickys on 18 revolver rims. dpf delete ccv mod
01 TDI jetta . Strait piped runnin on B100 summertime and B50 in the winter.
DRIVE IT LIKE YOU STOLE IT !
spence_08 is offline
