6.0 coolant leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 04-26-2014, 05:30 PM Thread Starter
Blue 6.0
6.0 coolant leak
Hey I've got an 04 with 03 motor 6.0 with 155/30s I just got new heads, studs, egr delete, and an ssx turbo. I drove it around after I left the shop and no leaks at all. Then I went home and went inside for about 30 minutes and when I went back outside there was coolant everywhere coming from behind the pulley under the altnater pulley. Could it be the intake manifold donut o-ring?? And why once I shut it off??
Blue 6.0 is offline
post #2 of 2 (permalink) Old 04-27-2014, 03:24 PM
spence_08's Avatar
Re: 6.0 coolant leak
maybe they didn't torque your intake down check the bolts also there is a line that runs from the degas bottle to right behind there make sure they put the clamp on it
08 superduty 6.4 fx4 sct live wire 9625or edge evo monitor flow pro 5 inch downpipe back. Afe stage 2 cold air intake 35 inch mickys on 18 revolver rims. dpf delete ccv mod
01 TDI jetta . Strait piped runnin on B100 summertime and B50 in the winter.
DRIVE IT LIKE YOU STOLE IT !
spence_08 is offline
