6.0 power loss at wot - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 04-25-2014, 08:13 AM Thread Starter
Onefast96svt's Avatar
I have no issues as in starting or idle. Trucks runs fine at normal stop light to stop light driving or even on the highway. But when I step on the pedal the engine revs and boost is made but it doesn't go anywhere. Speed will slowly climb while still driving fine( no hesitation or missing). Oil pressure is fine but I haven't checked fuel pressure yet. I just change fuel filter yesterday just to see if it would help. What do you guys think?
Onefast96svt is offline
post #2 of 15 (permalink) Old 04-25-2014, 11:13 AM
PursuitInterceptor
HeavyAssault's Avatar
Re: 6.0 power loss at wot
At what RPM are you experiencing the issue?? What is the boost PSI?
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #3 of 15 (permalink) Old 04-25-2014, 11:36 AM Thread Starter
All RPMs really.from a dead stop , turning at a light doing about 30, and going 60 I floored it each time and it goes but not like I floored it more like I was just half throttling to pass grandma doing 30 on a back road.
From what I have been able to see In the little time I've had , my scan gauge will show up to about 29 or so bug then starts showing -11 -14 and so on. It seems like the engine is Revving up fine and turbo is pushing boost fine but it's just moving. I'm going to check my fuel pressure today and may go buy a fuel pump just in case.
03 Excursion EB 4X4 6.0L Mineral Gray Metallic,20" machined/black Rockstars 33x12.50, 4" lift,Powerstop slotted and drilled rotors,Rancho adjustable shocks,Studs, looney tune wild,CCV MOD, Red Head Steering Box, EGR delete,6.4 banjo,XDP Coolant filter,4" MBPR straight pipe,280amp Alt,Amsoil oil bypass,Go Industries Bull Bar,6000k HIDs,ScanGaugeII
post #4 of 15 (permalink) Old 04-25-2014, 11:38 AM
PursuitInterceptor
Sounds more like a VGT side issue on the turbo. Consider the VGT solenoid and perhaps giving the turbine side a complete cleaning.
You dig.
post #5 of 15 (permalink) Old 04-25-2014, 11:42 AM Thread Starter
It was just in the shop last week to fix an oil leak from where a "reputable diesel shop" broke a bolt and striped 2 bolts on my turbo. So only 1 was holding it on torquing the top lines of the turbo making them leak. So my new friends which I trust fixed leak, replaced y pipe, did turbo oil line upgrade , and cleaned the turbo while it was out. Now maybe they got the turbo and didn't look at the solenoid. I'll have to call and ask.
post #6 of 15 (permalink) Old 04-25-2014, 11:48 AM
Fixing Broken Stuff
toolmangary's Avatar
^^, also look and EBP and MAP, make sure the tube is clear going the EPB sensor and the hose from the right side of the intake to the MAP is connected and good. Also what is readings EBP and MAP KOEO and KOER?
Most likely your problem is one of those three items.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #7 of 15 (permalink) Old 04-25-2014, 11:49 AM Thread Starter
I'll see what the readings are when I get home. May be 4 or so.
post #8 of 15 (permalink) Old 04-25-2014, 12:47 PM Thread Starter
Just to let my ignorance shine and not to google rape my phone, what are the sensors you speak of. I know the map bug the others not sure of. I'm sure once you tell me I'll be like ooh yeah, but sometimes I'm not good with short hand.
And if something was wrong with these sensors wouldn't I get a code ?
post #9 of 15 (permalink) Old 04-25-2014, 01:37 PM
Fixing Broken Stuff
EBP = exhaust back pressure
KOEO = key on engine off
KOER = key on engine run
2004 Jetta TDI
1956 F100
post #10 of 15 (permalink) Old 04-25-2014, 03:30 PM
What year truck? What does your injection pressure and duty cycle look like?
