2004 6.0 crazy steering issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-22-2014, 05:05 PM Thread Starter
Ok so recently I replaced the power steering, so I am thinking this issue may be the steering box or track bar. my mechanic says everything else looks fine, I.e. ball joints, etc
the issue: I'm going into a turn and I obviously am turning the wheel. when I am trying to come back to center the wheel fights me pretty hard like it doesn't want to go back the way I want it to. after I return the wheel to center there is now a few inches of play and the wheel is constantly grabbing left, right, left right..in a very wobbly manner. if I drive i get on the brakes a bit it seems to help or if I just bear through it and drive straight, it'll eventually go back to pretty much normal (only like 1/2inch of play and no wobbly
left to right). but as soon as I go into another turn it'll fight and wobble back and forth.
I have It lifted 4" with 35s on 20s. i did an aftermarket steering stabilizer and like I said, already relaxed the power steering bc it was doing this before. it was great after that for about 3 weeks and now it is back
to doing it again. there is also some wine I think I hear too. maybe a new ps pump, box? thoughts?? thank you!
RDC04_6.0 is offline
post #2 of 4 (permalink) Old 04-25-2014, 06:42 PM
spence_08's Avatar
Re: 2004 6.0 crazy steering issue
seized u joint in the front axle is your issue I believe
08 superduty 6.4 fx4 sct live wire 9625or edge evo monitor flow pro 5 inch downpipe back. Afe stage 2 cold air intake 35 inch mickys on 18 revolver rims. dpf delete ccv mod
01 TDI jetta . Strait piped runnin on B100 summertime and B50 in the winter.
DRIVE IT LIKE YOU STOLE IT !
spence_08 is offline
post #3 of 4 (permalink) Old 04-26-2014, 03:39 PM
'05 Excursion
Term3's Avatar
What he ^^^^^ said. Mine did the exact same thing when it seized up. Your power steering is whining because its always fighting the bad u-joint. Once you get it fixed I'd be inclined to do a power steering flush. When I was figuring my u-joint issue out I found my power steering fluid was super hot.
Sent from AutoGuide.com App
Term3 is offline
post #4 of 4 (permalink) Old 04-30-2014, 12:08 AM
^^^^^^^^^ I fought mine for a month trying to figure it out and it was u-joints in the front axle.
2005 F-250 Crew Cab 4x4 6.0 Powerstroke
FASS Fuel System 150gph
SCT Livewire TS
Everything Else Is Stock
raptorfever660 is offline
