cooler question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-22-2014, 01:05 AM Thread Starter
cope102's Avatar
cooler question
fixing to do the egr delet on my truck i have seen many saying to replace the cooler what is everyone replacing cooler with and also suggested replace sct fitting?
2004 F350 DRW FX4 Banks Six Gun Tuner,Egr delete, Adrenaline pump, Banks air, 4 inch straight pipe exhaust
cope102 is offline
post #2 of 6 (permalink) Old 04-22-2014, 01:08 AM
Re: cooler question
05+rucks need the new style stc fitting the old style will fail if you have the intake off its not much more to replace it. Use only ford oil cooler. the aftermarkets are junk
Fixing ford diesels since before they had turbochargers
wise guy is offline
post #3 of 6 (permalink) Old 04-22-2014, 02:29 AM Thread Starter
cope102's Avatar
Re: cooler question
cool thanks man!
cope102 is offline
post #4 of 6 (permalink) Old 04-22-2014, 02:58 AM
Wyo
scouts out...
Wyo's Avatar
Re: cooler question
I like my bullet proof external cooler, my first ford cooler failed and it was suggested to go with the revised ford cooler so I did, it failed as well. Both with coolant filter kits being used, fresh coolant flush all that good stuff. I did everything right and they still failed twice so I was done with it. Now I run the external with filter and haven't had a single issue yet. It is possible I got two bad apples, there are a lot of people that have great success with the ford coolers. My opinion I'm done with them.
2007 CC, Lariat, 6.0L, TreadWright guard dogs, straight piped out the back, egr delete, blue spring, 6.4 banjo bolts, high idle mod(bcp), bulletproofed, SCT Livewire TS with Drews street runner(under development for high elevation), Innovative, and Vivian's tunes, ww2.
Wyo is offline
post #5 of 6 (permalink) Old 04-22-2014, 03:23 AM Thread Starter
cope102's Avatar
Re: cooler question
so if you go with the external one does that mean yhou dont have a cooler any more?
cope102 is offline
post #6 of 6 (permalink) Old 04-22-2014, 03:57 AM
Wyo
scouts out...
Wyo's Avatar
Re: cooler question
I do have a cooler just not anything like what a OEM cooler is. Bullet Proof Diesel Heavy Duty Engine Oil Cooler
This is what I have. Except I also have the winter package installed. Sure it's kind of expensive, but I've got that much in failed OEM coolers/labor and this cooler is the last one I'll ever have to buy.
Wyo is offline
