cruise control and speedo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 04-21-2014, 07:18 PM Thread Starter
So in the last week or so my cruise has been kicking out, and its usually when I hit a larger bump.
So I was thinking that maybe there is a wire that has rubbed thru somewhere. But I just noticed today that when I hit the larger bumps in the road that my speedo bounces around. The speedo drops about 10 - 15 km/h. So now I'm not so sure that it is a bare wire somewhere. Where does a guy start looking?
weisers26 is offline
post #2 of 16 (permalink) Old 04-22-2014, 12:58 AM Thread Starter
Re: cruise control and speedo
Anybody? Anyone have some opinions?
post #3 of 16 (permalink) Old 04-23-2014, 07:02 PM
Diesel
Mach5Customs's Avatar
As far as the cruise, I have heard a bad clock spring behind the steering wheel can cause problems with cruise, horn and other steering wheel mounted buttons. And for the speedo try doing a gauge sweep by holding down the tripometer button and turning the key on then press it one more time and it should sweep gauges. After they sweep and go back to zero turn the key off and you should be good to go. See if that does anything for you.
05 6.0, bulletproofed, egr delete, 6.4 banjos, 4" turbo back, air raid intake, Cfm+ intake elbow, no limit cold side pipe, afe metal cold side pipe, Barder stage 2 turbo, MPD 175/75's, ported intake manifold, php custom Ficm tune, fass 200, driven diesel RR, IDP Xtreme X, insight cts with egt, fuel and boost, 08 front and rear end conversion.
Mach5Customs is offline
post #4 of 16 (permalink) Old 04-23-2014, 07:05 PM
Administrator
Zmann's Avatar
check the VSS in the rear dif a loss of signal will do what you have going on
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 16 (permalink) Old 04-23-2014, 07:09 PM
Administrator
Zmann's Avatar
this is your rear ABS and speedo sensor if the speed is interrupted your cruise cuts off ( understandably )
check wiring / pull and clean sensor / replace if needed
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 16 (permalink) Old 04-23-2014, 07:48 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
^^^ me gusta, but only time i've had issues with it, it also threw ABS codes along with speedo & cruise malfunction
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #7 of 16 (permalink) Old 04-24-2014, 03:14 PM Thread Starter
Right on guys. Thanks. I'll check that sensor on the diff. And yes, I forgot to mention that it was also throwing the abs light on. Hopefully thats all it is. Thank you very much.
post #8 of 16 (permalink) Old 04-27-2014, 03:42 PM Thread Starter
You guys were right. Turned out, it was just a broken wire at the speedo sensor on top of the diff. Thanks.
post #9 of 16 (permalink) Old 04-27-2014, 06:27 PM
Turd-250's Avatar
np! that's great that you got it fixed!
Turd-250 is offline
post #10 of 16 (permalink) Old 04-27-2014, 06:45 PM
Administrator
Zmann's Avatar
Turd-250
He was talking to Me turd
kidding Turd
glad it was easy !
DTR's Donation page
RIP DTR Ron
Zmann is offline
