Stiction Fixxin - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 04-21-2014, 10:07 AM Thread Starter
Gnarkle's Avatar
Stiction Fixxin
After much debate, I just did the injector spool valve polish/clean trick on my 2005 6.0 with 205XXX miles and woohoo! Runs 100% better!
The symptoms were pointing straight at injector stiction, would start and idle alright but driving it before the oil reached operating temp was a nightmare. Would buck and jump like crazy. This truck has had a steady diet of Rotella T6 also.
Probably the best six hours I have spent working on this truck, such an improvement.
Just wanted to share my success story in case anyone might have been on the fence about doing it. A few O-rings certainly beats the cost of new injectors!
Gnarkle is offline
post #2 of 14 (permalink) Old 04-21-2014, 01:28 PM
Re: Stiction Fixxin
What exactly did you do. I am having the same issues.
CATCARL is offline
post #3 of 14 (permalink) Old 04-21-2014, 06:54 PM Thread Starter
Gnarkle's Avatar
Re: Stiction Fixxin
Pulled all 8 injectors, removed the spool valves, cleaned/polished them up real quick with some 800 grit sand paper and WD-40. Re-installed with new O-rings and copper washers. There are tons of videos on youtube that show exactly what to do. Super simple.
Gnarkle is offline
post #4 of 14 (permalink) Old 04-22-2014, 08:27 PM
Re: Stiction Fixxin
Take a look at this-http://www.powerstroke.org/forum/general-6-0l-discussion/351594-fixing-stiction.html#post4509754
2006 F350 4X4 Lariat
Edge CTS
Dieslsite coolant filter
Blue spring update
Updated STC HPOP Fitting
SCT Tuner w/ Matt's tunes
Atlas 40 FICM tune from Ed
178,000 miles
Tinbender is offline
post #5 of 14 (permalink) Old 04-22-2014, 11:05 PM Thread Starter
Gnarkle's Avatar
Re: Stiction Fixxin
Thats pretty much exactly what i did, works great.
Gnarkle is offline
post #6 of 14 (permalink) Old 04-23-2014, 05:04 AM
Banned
Re: Stiction Fixxin
sixohdieselrage is offline
post #7 of 14 (permalink) Old 04-23-2014, 07:45 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
Re: Stiction Fixxin
sub'd!
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #8 of 14 (permalink) Old 04-24-2014, 06:02 PM
Re: Stiction Fixxin
You wouldn't happen to have before and after pictures of the spools, would you? I was going to do all of mine, but the first two I took apart showed absolutely no signs of varnish (on the spools), and they slid very smoothly through the bores. I didn't even take out the other six.
post #9 of 14 (permalink) Old 04-25-2014, 02:57 AM
lubeowner's Avatar
Re: Stiction Fixxin
Couple other things to remember, make sure you don't tighten the spool valve any more so that it still spins, but with resistance. People call me all the time with issues of the injector working great then starting to miss once hot. This is caused buy spool bolt being to tight. Second is the nut is a lock type bolt. I wheeze them a little to get them to lock on. Sometimes the nut will vibrate off if you don't.
Jeremy Johnson
Search "lubeowner" on youtube for many truck pulling videos.
dieseldr.net
We build Powerstroke pulling trucks.
lubeowner is offline
post #10 of 14 (permalink) Old 04-25-2014, 03:59 AM
Re: Stiction Fixxin
How tight exactly. I just snugged the nut, about as tight as it felt when taking it off
05 f250 ccsb
arp and ford gaskets
egr delete
4" straight pipe
homemade coolant filter
ccv reroute
zoodad
sct livewire, looney wild
powerstorkecrzy is offline
