the unsolvable problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 04-19-2014, 12:40 AM Thread Starter
super pro
Got an 06f250 been to 4 different shops and still no answers. 2 dealers and 2 powerstroke only specialty shops. Truck ran great decided to do headstuds egr delete and powermax turbo. After install the truck has never ran right and has the exact same symptoms without change or improvement fo about 1000miles now. Truck starts fine cold or warm regardless of outside temp. Truck has very little throttle responce slow turbo spool low boost and lots of lag. Injector are loud and has a minor miss. Fuel pressure never drops below 57psi icp is very strong and a little high at idle 770ish. Ipr duty cycle good check turbo every way possible. Its working good. Checked all boots and connectors uppipes.. you name it i probably checked it 10 times. No codes injectors check out good. I do have high ebp though on the big end. Reading in the mid to high 50s at 20psi of boost. It even revs slow in park. No smoke. Almost seems like injector timing is off. Had custom sct tuness written for pm. They helped but on street tune its stillmuch slower then a stock truck at any rpm. Lots of low end smoke with the tunes. None on top. Everything that can be tested with ids checks out... help me figure this out and i will mail you 200$. Lol... im at my wits end
truckguy876 is offline
post #2 of 20 (permalink) Old 04-19-2014, 01:00 AM
Administrator
Zmann's Avatar
Re: the unsolvable problem
I would be tempted to put the old turbo back on
only because if it true that this problem occurred with the addition of a turbo and head studs
I would want to isolate the problem
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 20 (permalink) Old 04-19-2014, 01:19 AM Thread Starter
super pro
I no longer have it
post #4 of 20 (permalink) Old 04-20-2014, 05:34 AM
I would install the original tune, as the power max should work fine. On your EGR delete, is your valve still in place? What delete kit was used? You should be able to get some result from a cylinder contribution test and run KOEO and KOER tests. A common problem I see after stud jobs are people do not tighten injectors down right and will develop a miss. Usually it is from not cleaning the oil from the hold down bolt holes. Last is to double check all injector and FICM connections.
lenzhotrod is offline
post #5 of 20 (permalink) Old 04-20-2014, 08:09 PM Thread Starter
super pro
Been running on stock tune. The truck runs pretty smooth just has no power. Tried with valve plugged in and unplugged. On stock tune exhaust doesnt have the rasp it use to. Its straight piped. Its an rcd delete. When injectors were installed i blew the oil out of the bolt hole using compressed air and torqued to spec. Checked ficm connectors a thousand times and checked pins on ficm too contribution and balance test checked out and all koeo and koer tests look good. Passed bubble test. Idk... does have icp on the high side and high ebp wile accerating.
post #6 of 20 (permalink) Old 04-20-2014, 08:23 PM
Six Point Slow
justinstorm77's Avatar
Had one of these same scenarios at the shop a few weeks back, it ended up being an injector failure that the ECM could not pick up. We used a cylinder performance analyzer to find the issue. Problem is the truck came back a few days ago for the same issue. Hav e not gotten back to it yet as we are pretty slammed with work. I'll let you know what we find.
justinstorm77 is offline
post #7 of 20 (permalink) Old 04-20-2014, 08:44 PM
whistle tits
ghohouston's Avatar
Checked map sensor line, and made sure the nipple is clear all through the intake?
ghohouston is offline
post #8 of 20 (permalink) Old 04-20-2014, 09:53 PM Thread Starter
super pro
Map tube and nipple good.. not clogged no holes
post #9 of 20 (permalink) Old 04-20-2014, 09:59 PM Thread Starter
super pro
With stock tune it runs smooth with no smoke at any rpm. Revs slow when in park and is overall extreamly slow. Like slower than 6.9 idi. The injectors are really loud. More so on passengers side. Low boost. Tons of lag. No codes.
post #10 of 20 (permalink) Old 04-20-2014, 10:02 PM Thread Starter
super pro
Wont even spin the tires in the dirt.
