Blown pcm fuse. What gives? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-17-2014, 01:58 AM Thread Starter
Truck shut off while driving. No symptoms just shut off and would not crank. Ended up being a blown pcm fuse. Popped in a new one and all is well. What triggered the fuse to blow? Also, getting a check engine light after start up. Runs great. If I clear the light while driving it doesn't come on. SCT won't pull the code.
2016 F550 6.7 9' Dump work truck
2006 F350 6.0 Auto 95k miles. Sct programmer. 5 inch exhaust. Blue spring mod. Suspension mods and 35's.
1997 F350 7.3 Reg cab. Exhaust, coolant filter, front 2.25 PMF Rsk with Superduty Leafs.
gtmustang00 is offline
post #2 of 8 (permalink) Old 04-17-2014, 09:05 PM Thread Starter
Re: Blown pcm fuse. What gives?
Just hooked up Snap on Scanner. Code 1102 MAF Lower in range than expected.
post #3 of 8 (permalink) Old 04-17-2014, 10:03 PM
"Slap hands slap hands"
FlossyB's Avatar
my truck just did the exact same thing last week when I was towing my boat to lake. Was frustrating as hell. There was a wire that was loose and harness that needed to be replaced and wires cleaned up and relocated so it doesn't happen again with my truck. It blew the fuse, no issues after replacing the harness, relocating and cleaning up wires.
JB
FlossyB is offline
post #4 of 8 (permalink) Old 04-17-2014, 10:52 PM Thread Starter
The pcm fuse or the p1102 maf code? Where was it chaffing? Can you take a picture for me? Thanks!
post #5 of 8 (permalink) Old 04-18-2014, 02:18 AM
FlossyB's Avatar
the PCM fuse its already fixed and its up and running again. it was a wire that was exposed right by the harness.
JB
FlossyB is offline
post #6 of 8 (permalink) Old 04-23-2014, 01:42 AM Thread Starter
Anybody else have this issue?
post #7 of 8 (permalink) Old 04-23-2014, 08:36 PM Thread Starter
What harness did you have to replace?
post #8 of 8 (permalink) Old 04-25-2014, 02:12 AM Thread Starter
I found a break in the red wire, down about 18 inches or so where it meets the other harness's in the bundle. Soldered it back together and going for a drive now.
