Driving on bad turbo seal? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-16-2014, 12:01 PM Thread Starter
K
Punnisher's Avatar
Ok so if I did have a seal issue and with truck running fine just the smoke issue under acceleration and the need to add oil weekly can I hurt my injectors buring all that oil? Can the turbo fail? Askin cause I need to get to work and not fixin truck for a few weeks.Should I drive it?
I can eat 10 pieces of French Toast!
Punnisher is offline
post #2 of 4 (permalink) Old 04-16-2014, 01:35 PM
Bobs 7.3
Bobs 7.3's Avatar
Re: Driving on bad turbo seal?
Could cause a runaway engine then it will just rev up and run on the oil its getting fed threw the turbos bad seal till she blows.
Bobs 7.3 is offline
post #3 of 4 (permalink) Old 04-16-2014, 04:41 PM
Fixing Broken Stuff
toolmangary's Avatar
Which side of the turbo is the oil leaking too?
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #4 of 4 (permalink) Old 04-16-2014, 10:20 PM Thread Starter
K
Punnisher's Avatar
Exhaust not that dark but smells like burnt oil and yeah blue tint to it for sure so maybe not buring internaly but on exit side? I see oil in tail pipe not a lot but enough.
