Hard truth about the 6.0??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-16-2014, 01:59 AM Thread Starter
BigRed02
BigRed02's Avatar
Hey guys, lookin for a 4 door to replace my ext cab, and I've found a LOT if beautiful trucks running the 6.0
I've also heard bad bad things since these came around.
I've never personally drivin or known someone that owned one, so I don't know what the truth is.
So should I be reluctant to get one? Most of the ones I've seen have over 100k.
Spencer
2000 F350 CCLB 4x4 7.3L, 4R100, 6637, 4" MBRP turbo back
2000 F250 Red 4x4 Ext. Cab, 7.3L DI, ZF-6
2005 Ranger Dark Gray, FX4, 4 dr, 4.0 SOHC, 5r55e
2015 Ford Transit 3500, Dark Gray, HR EX, 3.5L ecoboost, 6 speed select shift
2011 Edge Limited Black, 3.5L
BigRed02 is offline
post #2 of 12 (permalink) Old 04-16-2014, 03:35 AM
Wyo
scouts out...
Wyo's Avatar
Re: Hard truth about the 6.0???
I was never a fan of the 6.0, but when I was looking for a crew cab ford I came across a killer deal. I looked it over with a fine tooth comb, all seemed well but I knew I was going to break something because I'm hard on trucks anyhow. I did the research and started to save my money to replace all the known weak points. While I was saving I blew a head gasket which forced me to make the repairs sooner then expected but I knew it was coming. Now that I have all the weak point fixed and am running custom tunes this truck is bad ass and I'm glad I made to purchase even being a 6.0L I say if you come by a killer deal then take it but plan on fixing the weak points either before or after they fail.
2007 CC, Lariat, 6.0L, TreadWright guard dogs, straight piped out the back, egr delete, blue spring, 6.4 banjo bolts, high idle mod(bcp), bulletproofed, SCT Livewire TS with Drews street runner(under development for high elevation), Innovative, and Vivian's tunes, ww2.
Wyo is offline
post #3 of 12 (permalink) Old 04-16-2014, 04:08 AM
Big dumb redneck
6speedSD's Avatar
Garage
The bad news... Yes 6.0's have weak points. All vehicles have a weak spot or two...these have several, and can't cost a small fortune in repair bills...especially if you are the type to take it to a shop for everything. Parts are expensive, labor rates are outrageous.
Now, the good...every known issue with these trucks is 100% fixable. The aftermarket stepped up big time offering every updated/better part available that you can think of. With a little bit of work and money, a 6.0 can be made as reliable as any other vehicle out there...if not even more so. Key thing to remember is routine maintenance is KEY with a 6.0. They can be bought for cheap in most cases because most people think they aren't worth anything. I'm on my second 6.0, and if I needed to buy another truck for whatever reason, I can say with 100% certainty that I'd buy another 6.0. I've had no major issues with either truck, but I know the inevitable is bound to happen eventually. When it does, I'll fix it and keep on driving. If you are mechanically inclined and work on your own stuff, you'll save yourself thousands in labor fees.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #4 of 12 (permalink) Old 04-16-2014, 11:12 AM Thread Starter
BigRed02
BigRed02's Avatar
Thank y'all off the input. This is very helpful!
Well I feel a little better about my available selections now, and I agree that there are some deals out there because of this engine.
I'm a 7.3 guy, and had always heard to beware, but this makes a lot of sense now. I am a decent mechanic, and believe I could handle anything it could require.
I may just hunt for that truck, even with the 6.0, and I'll keep in mind the cost that I might assume by whipping it into shape after I buy it...
Thanks guys!
BigRed02 is offline
post #5 of 12 (permalink) Old 04-16-2014, 05:37 PM
You will always hear more complaints than praise. I absolutely love my 6.0. They have more power and get better fuel mileage than the 7.3.
lenzhotrod is offline
post #6 of 12 (permalink) Old 04-17-2014, 03:25 PM
^ That is extremely well stated.
I absolutely love my truck. It's a bad*** engine, makes tons of power (I'm always amazed at how quickly is can move a 3.5 ton empty truck), and the sound is unreal.
Maintenance is key. Oil every 5k. Fuel filters every 10k. Coolant is unbelievably important. If I were to get another 6.0 (and the oil cooler wasn't already 100% clogged...) I would flush, flush, and flush (including backflushes through the oil cooler and heater core) with running water until you could drink the water draining out. I would then flush with Restore. I would then flush, flush, flush again. Then flush with Restore Plus. I would flush, flush, flush, then flush again with distilled water. Finally, I would fill with an extended life HD Cat EC-1 approved silicate free coolant. Oh, I'd add a coolant filter before the final fill. (< I will be doing all this to my truck this spring once it's running again)
post #7 of 12 (permalink) Old 04-18-2014, 12:58 AM
Love my two 6.0L I have the 03 in my signature that I've done everything to and an 05 bone stock with 300000 miles on it. The only issues I've had with my 05 is the FICM went bad and I had to put a set of injectors in it. If you are a mechanic or mechanically inclined you can do all the fix its for around $5000 in parts. I'd buy another 6.0 in a second without a second thought and because most people are so afraid of them you can usually get a great deal on a 6.0
09 SCREW 4X4
acplowboy84 is offline
post #8 of 12 (permalink) Old 04-18-2014, 02:05 AM
Professional American, guarding our constitution. Gone, but not forgotten.
Mr_Andy's Avatar
They went thru stages just like the 6.4 did. The first ones (03.5-04) had a laundry list of failures... As the years went on they improved on it and ironed these failures out but the problems remain. Head bolts/gaskets most of all, and there's nothing you can really do to improve it because you simply can't put more bolts in the block to make up for the lack therein. As batteries get old and the alternator(s) lose oomph, the FICM takes a beating from low voltage issues. The PCM had issues as well. I think a lot of bad rap comes as a result of *under* driving these motors tho. People who drive a diesel like a gasser - fire it up to pick up Timmy at school and bring him home - lend cause to many of these horror stories. Oh, don't forget to give it a revving before you shut the ignition off too. If you find a deal on one that's still running and running strong, chances are it was well maintained and it's gonna keep running that way as long as you keep it's blood clean and keep running it like it wants to be run. Hard and at operating temp for a lot longer than 15 minutes.
Mr_Andy is offline
post #9 of 12 (permalink) Old 04-18-2014, 02:18 AM
This is great information. I'm in the market for a diesel too and find a lot of 6.0's for a decent price.
03_PSD is offline
post #10 of 12 (permalink) Old 04-18-2014, 01:54 PM
K
Punnisher's Avatar
Love drivin it!! Hate fixin it!! labour intensive and complicated!!!
I can eat 10 pieces of French Toast!
Punnisher is offline
