Shrapnel in engine oil regulator!?! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 04-16-2014, 12:51 AM Thread Starter
Bronze fire 350 Platinum
Hello, I have been on and off this site for a couple of trouble free years of owning my 05 f250 xlt xcab 4x4.... Bla... Bla. Over the years I have done an egr delete, coolant filter, oil cooler, 4" turbo back strait pipe. The first time in my 19 years of owning ford vehicles I was left on the side of the rd. dead in the water. It was a hpo system leak... Or should I say leaks. Anyhow... After pricing out new upgraded 190s, resealing the hporail, stc, dummy plug/ standpipe update, new turbo/intercooler to feed the injectors with enough cold air ( I regualarily tow 12000+lbs) with a 303000 km engine. I bought a complete engine with 150000 km from a wrecker... I installed a 6 phase bpd ficm at the same time as the engine. It purred like my dreams come true! I made a few test trips all with my scan tool hooked up data logging... Everything was perfect. So Saturday I drive 210km to the city for groceries. Starts fine all day( scan tool hooked up the whole while). When I go to start the truck to leave for home... It starts fine and oil press. registers, when I put it in drive, the needle dropped and the truck stalled out. Only codes were low icp and crank sensor circuit low. After swapping the ckp sensor Everything on scan tool was good;save for icp. So I disconnected the sensor and still no start. I then pulled oil press. Reg. and found a piece of metal in the valve, I then tried to figure it what this piece of metal might be; for the life of me I can't figure it out. If anyone could help me out it'd be muchly appreciated!
Stripp is offline
post #2 of 16 (permalink) Old 04-16-2014, 01:09 AM Thread Starter
Re: Shrapnel in engine oil regulator!?!
I have since overfilled crankcase with oil, jacked up the back and cranked. Still no oil to the filter housing and no oil in regulator after cranking. I have torn into my other engine... Looked at everything above the block deck and have not found anything that looks like this... Is it possibly a piece of the stc fitting?
Stripp is offline
post #3 of 16 (permalink) Old 04-16-2014, 01:26 AM
whistle tits
ghohouston's Avatar
Hard to say from such a small picture, but regardless, you probably need a new lpop, and possiblt cam and lifters. 6.0's are notorious for breaking lifters, and taking out the lpop and cams
ghohouston is offline
post #4 of 16 (permalink) Old 04-16-2014, 01:45 AM
Luddite in Charge
Mr_Andy's Avatar
Again, hard to say, but is the base (as it's sitting in the pic) a fracture line? It could be part of a pushrod socket from one of your lifters.. Could be umpteen other things too.
Mr_Andy is offline
post #5 of 16 (permalink) Old 04-16-2014, 03:15 AM
Big dumb redneck
6speedSD's Avatar
Garage
Duuuuude....your avatar.....
Sorry...derail over.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #6 of 16 (permalink) Old 04-16-2014, 04:02 AM Thread Starter
No there were two fractures, from the shape I was thinkn it was a lifter cup, but they look totally different. Ill try to get pic bigger
Stripp is offline
post #7 of 16 (permalink) Old 04-16-2014, 05:04 AM Thread Starter
Is there a steel seat for the regulator in the front cover?
Stripp is offline
post #8 of 16 (permalink) Old 04-16-2014, 05:14 AM Thread Starter
I can't seem to get a better pic with my phone ill try again tmorrow with camera
Stripp is offline
post #9 of 16 (permalink) Old 04-16-2014, 11:01 PM
i would say lifter bearing its starting to break open if it hasnt already
one day...
2006 silver f350 crew cab
5i1v3rback02 is offline
post #10 of 16 (permalink) Old 04-16-2014, 11:03 PM
and you probably need to reprime the low oil pressure system also... try using some wheel bearing grease in the oil pressure reg. hole(better if you can put the grease right into the low pressure oil pump itself)
one day...
