03 250 diff & t-case fluid & capacity info/advice needed - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-15-2014, 08:05 PM Thread Starter
cook03F250's Avatar
Hey ya'all, going to change fluids. Need amount and type of recommendations.
It does have a trac loc rear. If I use synthetic, do I still need the modifier additive?
TIA ~ Matt
cook03F250 is offline
post #2 of 3 (permalink) Old 04-16-2014, 05:44 AM
duck fan's Avatar
Re: 03 250 diff & t-case fluid & capacity info/advice needed
These are the guides I used. Each one has the fluid specifications and capacities. You should be good to go.
Front diff change: http://www.guzzle7pt3.com/fdiff.php
Rear diff change: http://www.guzzle7pt3.com/rdiff.php
Transfer case change: http://www.guzzle7pt3.com/transfer.php
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 3 (permalink) Old 04-16-2014, 12:36 PM Thread Starter
cook03F250's Avatar
Those are great!
Thank you!
