6.0 engine rebuild - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-15-2014, 03:06 AM Thread Starter
6.0 engine rebuild
So I picked up a used 2003 6.0 engine. Engine had 80,000 and was diagnosed with a bad camshaft by a diesel shop. Turbo, ficm, and injectors are gone.
Just looking for ideas to start a rebuild.
Would the best way to go be to buy a rebuild kit? Or just put together what I want. I want to just build a good and reliable daily driver. Maybe a bigger turbo and larger injectors but not tell I get the small stuff done.
I will start with
Egr delete
Arp head studs
Not sure where to go from there. As I'm some what still new to the 6.0 platform
Thanks
Tj561CO is offline
post #2 of 4 (permalink) Old 04-15-2014, 03:49 AM
Re: 6.0 engine rebuild
You might want to start with a good cam and lifters.
lenzhotrod is offline
post #3 of 4 (permalink) Old 04-15-2014, 04:05 AM
2Dstorm's Avatar
Punch it 40 and do a colt stage 1 cam get the heads worked. Ported intake steed speed manifolds and custom ypipes 68 mm turbo and some 175/75 injectors will get you in the 600 to 650 rwhp range
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #4 of 4 (permalink) Old 04-15-2014, 01:15 PM
What did you have to give for it?
