vaccum/heater problems! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-14-2014, 03:04 PM Thread Starter
oilfield trucker
zpilgeram's Avatar
I have no vaccum in my cab to the heater controls, I have vacuum at the vac canister when I pull the vac lines off tho. My truck does not have auto hubs so I don't have vac lines that could leak there. Mr question is this, if I have vaccum under the hood but not in the cab, where am I losing it at? If I'm not mistaken, if I had a vac leak in the cab somewhere, wouldn't the canister lose it vaccum fairly quickly and the vac pump be kicking on a lot? That isn't the case for me, the canister will hold vaccum overnight which kinda tells me I don't have a vac leak. I took the connection lose at the plug behind the glove box, the black and white vac lines, if I'm not mistaken, the black line is coming directly from the vac canister and going to the blend control knob, the white line goes to the water shut off valve under the hood, is that correct? Thanks
96cc,lb,4x4,zf5. DIY dual filter intake, intercooled,gauges,4''down pipe, DIY front bumper/grill guard,fuel tank mod, 238cc Rosewood Diesel hybrids,6pos chip from TDP,
stealth SRP1 HPOP,Garrett GT4294 with DIY mounting kit,valair 500hp kevlar/ceramic clutch,Dual SD pumps electric fuel system with regulated return,5'' DIY Straight pipe.
zpilgeram is offline
post #2 of 4 (permalink) Old 04-19-2014, 10:33 AM Thread Starter
oilfield trucker
zpilgeram's Avatar
Re: vaccum/heater problems!
Anybody?
post #3 of 4 (permalink) Old 04-21-2014, 02:50 AM
yes your right about the vacuum line black is the feed and white is the heater shut off, but is your pump running all the time? also pull the liner from the fender and you will see the vacuum lines going into the firewall they are easily traceble
polish pete is offline
post #4 of 4 (permalink) Old 04-21-2014, 04:19 PM Thread Starter
oilfield trucker
zpilgeram's Avatar
No, pump will only run for a few seconds, then kick off. Thanks for the reply!
