Hydraulic leak in the injector(s)? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-13-2014, 02:21 AM Thread Starter
Today I finally got my high pressure oil system completely back together. Just to be sure before I buttoned it back up (HPOP cover), I put ~125 PSI air on the system via the port where the HPOP cover connects. Much to my dismay, I heard more than one leak.
I pulled off one of the oil manifolds and then applied the air directly to the port on the top of the injectors. Two of the four on the passenger side leaked (I didn't pull apart the driver side yet). It appears the air is escaping from the small holes around the main hydraulic hole on the top of the injectors.
So my question is: Is this bad? I have a feeling it is, but I thought I'd ask. If it is a problem, what can I do to remedy it? Are new injectors the only option? Is it common for injectors to leak on the hydraulic side like this? I have a lot of money into this project already and would rather not put a ton more into it right now.
By the way, I have already installed new ball tube O-rings, new top (ball tube connection) seals on the injectors, and a new HPOP. I would like to replace the remaining seals (the ones at the flex hose connections), but I'm not sure where to get these, or even if they can be replaced. It is the early high pressure oil setup, by the way.
Thanks for to anyone who can shed some light on this injector thing.
post #2 of 6 (permalink) Old 04-13-2014, 05:04 PM
Re: Hydraulic leak in the injector(s)?
have you tried to start it yet? aka is there any oil in the hp system at all? if not dont worry about it try starting it first, its happened to me before its because theres no oil and the orings wont seal with just air they need the oil pressure to seal correctly.
polish pete is offline
post #3 of 6 (permalink) Old 04-13-2014, 08:37 PM Thread Starter
Exactly the answer I was hoping for. No, I haven't attempted starting yet. I will do exactly what you said. I was thinking last night about the spool valves in the top of the injectors and how if they were filled with air instead of oil that they wouldn't seal.
I was doing some searching last night and I found the procedure for cleaning the spool in the top of the injectors. I think I am going to do this. I already have the fresh seals to reinstall the injectors, and I might as well take care of a small stiction problem while I'm here.
Thanks a lot!
post #4 of 6 (permalink) Old 04-13-2014, 11:33 PM
Big dumb redneck
6speedSD's Avatar
Garage
Stiction doesn't always mean dirty spools. They could just be worn. How many miles on the injectors?
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #5 of 6 (permalink) Old 04-14-2014, 03:08 AM Thread Starter
Boy, you guys are on top of this thread! Here's the story:
First, I don't think I have a terrible stiction problem, just when it was cold it was a bit rough and lacking power. Not terrible.
I started with injector numbers one and two today. When I pulled them apart, both showed no evidence of varnish. I mean, absolutely none. And, both moved very freely throughout the bore. At that point, I really didn't feel like spending the time I take out six more injectors to "fix" a problem that wasn't there.
The truck has 166k miles on it. I did notice that the spools did show some wear. So, it looks like if stiction ever becomes a big problem, I'll be looking at a new set of injectors then.
Thanks much, again!
post #6 of 6 (permalink) Old 04-14-2014, 03:35 AM
Big dumb redneck
6speedSD's Avatar
Garage
We've all been there at some point. I have a case of it with mine at 155,000 miles. Always just plug it up when it's going to be cold. If I don't it runs pretty rough for a bit. I live in a close quarters neighborhood, so that rough sounding mess echoes up and down the street! I did however recently load up Eric's Inductive Heat FICM tune.... Completely eliminated that rough cold weather startup.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
