Stranded at a gas station - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 04-12-2014, 07:06 PM Thread Starter
06 FX4,4" Rough Country
Bleed Blue's Avatar
I've got someone coming to pick me up, but I'm looking for help troubleshooting it. Yes I've read the no start trouble shoot thread. Anyways trucks been doin fine, I just drove 2 mins from the gym to the gas station and turned it off to run inside and when I came out it won't even turn over. Just sounds like a vaccum. All the gauges work so I'm guessing its not the battery, and the oil press gauge won't move so I'm guessing its got zero oil pressure? Seems idiot proof there just looking for all the opinions I can get and what to do next.
06 F250 CCLB FX4, 173K, Egr delete, Blue spring, SCT performance tune, AFE cold air, 4" Rough Country, 35x12.50 Cooper STT m/t, Fuel Hostage 18x12 -44 offset, 4"dp into 5" Diamond Eye system
Bleed Blue is offline
post #2 of 14 (permalink) Old 04-12-2014, 09:53 PM
Administrator
Zmann's Avatar
Re: Stranded at a gas station
sounds like a vacuum ?
starter just spinning but not engaging the flywheel ??
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 14 (permalink) Old 04-12-2014, 10:46 PM Thread Starter
Bleed Blue's Avatar
If that's the case what would the problem be?
post #4 of 14 (permalink) Old 04-12-2014, 11:42 PM
Terminator Nation
If the starter is turning over and the engine isn't, you need a new starter because the starter drive is not engaging.
old man dave is offline
post #5 of 14 (permalink) Old 04-13-2014, 02:22 AM
Banned
The bendix isnt popping out like it is supposed to.
miller45103 is offline
post #6 of 14 (permalink) Old 04-13-2014, 03:18 AM
'05 Excursion
Term3's Avatar
If you can get to it sometimes a good whack will free it unless its dead.
Sent from AutoGuide.com App
Term3 is offline
post #7 of 14 (permalink) Old 04-13-2014, 02:46 PM
Administrator
Zmann's Avatar
Agreed unless your flywheel is the issue (not likely)
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 14 (permalink) Old 04-13-2014, 03:14 PM
Banned
Yup. We've been having that issue with our skid steer recently. Bendix won't pop out so we have to hit it with a hammer. Only does it in cold weather though.
post #9 of 14 (permalink) Old 04-13-2014, 05:06 PM Thread Starter
Bleed Blue's Avatar
Well I got under it to hit it with a hammer and when I did I realized that one of the bolts holding the starter on was broke off and laying under my axel. Apparently it came out yeaterday when I tried to start it. I'd been hearing an annoying rattling sound a few weeks and couldn't find it to save my life and now I'm guessing that's what it was. Problem is I'm sure the bolt broke off in the threads. So when I get that out I just put a new bolt in an try to start it up I guess
post #10 of 14 (permalink) Old 04-13-2014, 07:18 PM
"Slap hands slap hands"
FlossyB's Avatar
good luck same exact thing happened to me expect a chunk of my started and the bolt broke off the starter and to boot it was in the Venetian parking garage so I couldn't even low boy tow it out because of clearance issues. was pretty embarrassing crawling under my truck and changing out a starter in the middle of valet but it fixed the problem which is all I cared about. keep us posted if that fixes it or not sounds like its a easy cheap fix hopefully.
JB
FlossyB is offline
