Where's my coolant coming from? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-11-2014, 05:09 PM Thread Starter
$HUNGRY6.0
Just replaced my radiator and refilled the degas bottle to minimum line. Kept checking it to top off as air bleeds out. Added maybe another quart when the level dropped. It's been just fine temp wise but every time I check the level COLD it's around the max line. I've drained some out a coue times to get it back to min ( I have the pre updated sticker where min is max). Keeps creeping back up around max. Any ideas?
2006 F350 cclb 6spd, studded, mbrp 5" TB, Full Force 225cc injectors, S467.7, custom pedistal & up pipes w/ext waste gate, egr delete, sinister coolant filter,new oem oil cooler, custom IC pipes, Thumper II HPOP, RCD reg return, SCT custom tunes, southbend clutch single disk, custom fab 4.5" lift, 315/70r18 toyo mt
Esp0660 is offline
post #2 of 8 (permalink) Old 04-11-2014, 05:14 PM
Re: Where's my coolant coming from?
does it smell like fuel in the bottle by chance? any bubbles?
95 f250 ECLB,silver/purple 199k FFD 350/200s, arps, comp 910 shimmed, BTS ZF delete, glowshift EGT,Boost,trans temp,6" aussies,6637, 6.oh IC,dual sd elec fuel. irate T4, S475/96,136k 97 motor. Twin termies
Plans: twin turbs, crowers and fresh rebuild.
rideracelivemx7 is offline
post #3 of 8 (permalink) Old 04-11-2014, 05:25 PM Thread Starter
$HUNGRY6.0
Doesn't smell like fuel, and not really bubbles just turbulence from where the tube comes in to feed coolant. That's obviously while it's running and at operating temp
Esp0660 is offline
post #4 of 8 (permalink) Old 04-11-2014, 05:35 PM Thread Starter
$HUNGRY6.0
No foam on top to speak of
Esp0660 is offline
post #5 of 8 (permalink) Old 04-12-2014, 12:24 AM Thread Starter
$HUNGRY6.0
Anyone?
Esp0660 is offline
post #6 of 8 (permalink) Old 04-12-2014, 01:23 AM
whistle tits
ghohouston's Avatar
If you're not overflowing the degas bottle, and no fuel in your coolant, you probably just added a bit too much coolant, and should be fine
ghohouston is offline
post #7 of 8 (permalink) Old 04-12-2014, 02:28 AM Thread Starter
$HUNGRY6.0
It does leak a bit but I figured it was due to overfilling. When I replaced the radiator I also replaced the degas bottle and cap. Don't think it's head gaskets since there's no smoke, changed oil a couple days ago and no contaminants. No foam in degas so... Idk never experienced this issue. Runs great otherwise
Esp0660 is offline
post #8 of 8 (permalink) Old 05-02-2014, 06:10 PM
My truck is doing the same thing. Some days it's at "Min" other days it's over Max, when it's over max it spills. I don't understand why it's doing it. There's no consistency in it. warmed up or cold the level fluctuates.
xsfpns is offline
