Very high EBP. Help me out. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 04-11-2014, 01:07 AM Thread Starter
Wyo
scouts out...
Wyo's Avatar
So Drew and I are working on a high altitude tune. He asked for some numbers from me to tweak the tune. One he asked for was EBP in kpa, with the truck not running and key forward I'm showing 260.07 kpa. Is this common for high elevation or do I have a malfunction somewhere?
2007 CC, Lariat, 6.0L, TreadWright guard dogs, straight piped out the back, egr delete, blue spring, 6.4 banjo bolts, high idle mod(bcp), bulletproofed, SCT Livewire TS with Drews street runner(under development for high elevation), Innovative, and Vivian's tunes, ww2.
Wyo is offline
post #2 of 11 (permalink) Old 04-11-2014, 02:53 AM Thread Starter
Wyo
scouts out...
Wyo's Avatar
Re: Very high EBP. Help me out.
Anything guys?
Wyo is offline
post #3 of 11 (permalink) Old 04-11-2014, 12:17 PM
If I remember correctly 14.7 PSI = 100 kpa (about). You may have a biased EBP sensor!
lenzhotrod is offline
post #4 of 11 (permalink) Old 04-11-2014, 12:55 PM
Fixing Broken Stuff
toolmangary's Avatar
260.07 kpa is 37.71 psi
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #5 of 11 (permalink) Old 04-11-2014, 01:13 PM Thread Starter
Wyo
scouts out...
Wyo's Avatar
Yeah but I'm getting that number with the truck not even running. With it running it's 350 kpa and if I get in it real hard it will go up to 900 kpa. I'm think something isn't right I'm just not sure if the altitude is the cause or some malfunction. I thought I read somewhere that the SCT has trouble with some readings at this kind of elevation.
Wyo is offline
post #6 of 11 (permalink) Old 04-11-2014, 01:37 PM
Your altitude has a little to do with it, not that much. 14.7 is at sea level I think you lose about .1 per 1000 feet roughly. What does your BARO read?
post #7 of 11 (permalink) Old 04-11-2014, 01:40 PM
With your KOEO your BARO,MAP, and EBP should all show close to the same readings.
post #8 of 11 (permalink) Old 04-11-2014, 01:45 PM Thread Starter
Wyo
scouts out...
Wyo's Avatar
KOEO Baro is 78.3 map is 78.75 EBP 269.21
Wyo is offline
post #9 of 11 (permalink) Old 04-11-2014, 02:18 PM Thread Starter
Wyo
scouts out...
Wyo's Avatar
Thanks for the help guys, I guess I'll be reading up on the cause of bad EBP readings and how to clean/replace it.
Wyo is offline
post #10 of 11 (permalink) Old 04-11-2014, 04:43 PM
im at 3500ft and my baro reads 14.5 fyi
95 f250 ECLB,silver/purple 199k FFD 350/200s, arps, comp 910 shimmed, BTS ZF delete, glowshift EGT,Boost,trans temp,6" aussies,6637, 6.oh IC,dual sd elec fuel. irate T4, S475/96,136k 97 motor. Twin termies
Plans: twin turbs, crowers and fresh rebuild.
rideracelivemx7 is offline
