2004 F350 Trans not shifting - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 04-10-2014, 02:10 PM Thread Starter
Angry 2004 F350 Trans not shifting
Guys,
Drove home last night, parked the truck, no issues. Went to go to work this morning and the truck would not move in drive.
What is wierd is that I did not seem to have neutral. When I shifted into reverse the truck would back up. When I shifted into neutral the truck would also back up.
In drive it acted like neutral unless i gave it a large amount of throttle, then it would move slowly like the brake was on. I checked the emergency brake and rear and front brakes and found none sticking. It also moved easily in reverse so I don't think that is it.
It did not throw any codes and the tow/haul light did not come on flashing.
Anyone experience this? It is a 2004 F350 CCLB with SPD tune, 35" tires, and a 6" lift. I have studs, EGR delete, 4" exhaust, and a BDP external oil cooler.
I have not done anything to the truck recently.
Thanks for the help,
Sean
seanol is offline
post #2 of 23 (permalink) Old 04-10-2014, 09:52 PM
matthewd11's Avatar
Re: 2004 F350 Trans not shifting
sounds like your low/reverse clutches are welded together somehow, or the reverse clutch piston is stuck on. Only way it would explain movement in neutral. Is the cable in tact and not stretched and adjusted properly?
matthewd11 is offline
post #3 of 23 (permalink) Old 04-10-2014, 11:47 PM
matthewd11's Avatar
the "binding" you feel is likely a tie up in the transmission. Its fighting itself which direction it wants to move the truck. Dont push on the throttle. Trans needs to come apart to see what the failure was IMO.
post #4 of 23 (permalink) Old 04-11-2014, 01:32 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
It could be a stuck solenoid E.
Mark
Mark Kovalsky is offline
post #5 of 23 (permalink) Old 04-11-2014, 02:27 AM Thread Starter
Mark,
I am getting one tomorrow and I will post the results.
Sean
seanol is offline
post #6 of 23 (permalink) Old 04-11-2014, 11:16 AM
matthewd11's Avatar
wouldnt that throw a code mark? Just wondering.
post #7 of 23 (permalink) Old 04-11-2014, 01:45 PM
It should.
Mark
post #8 of 23 (permalink) Old 04-11-2014, 03:49 PM Thread Starter
I tried the Torque app as well as the SCT X3 tuner and neither showed the code.
It is quite possible neither will show trans codes so I am not too worried. I did think that the tow/haul button would flash when a code was stored but it is possible that it will only do that when there is something catastrophic happening.
I have a new E solenoid and will install it this afternoon. I will update the thread with the results so good or bad all can learn from my adventure.
Thanks,
Sean
seanol is offline
post #9 of 23 (permalink) Old 04-11-2014, 04:21 PM
The tow/haul light will flash whenever a transmission code is stored.
Mark
post #10 of 23 (permalink) Old 04-12-2014, 02:42 AM Thread Starter
Mark,
Changed the E solenoid and nothing. Dropped the pan again and took out the valve body and cleaned each solenoid. Still nothing.
Tried a different code reader, a Mac reader with Trans reading capability and still nothing.
No tow/haul flashing either.
I am stumped.
Thanks,
Sean
seanol is offline
