2005 F350 6.0 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-10-2014, 03:10 AM Thread Starter
ropinpete's Avatar
2005 F350 6.0
First started this 4 days ago. I went to start the truck and it just cranked over. Tried it 4 times n no start. I got back 3 hours later cycled key crank no start. I decided to see if I could hear fuel pump. Turned key on n heard injectors n pump buzzing. Let glow plugs finish cycle n tried again n it fired up.
I decided to let it sit again n drove today. Started ran fine. Has several times since. Tonight after worked started truck n the battery light came on. I gave it a little throttle n the light went off. Driving home it came on again. I tested alternator n had 12.1 on post n the red wire in plug. Had 1.7 on the light green wire. Are these two issues related or is the truck telling me it wants a nap? When I listen for the pump it almost sounds like its pushing air bubbles. I am gonna take secondary fuel filter out n see if there is air coming out or fuel. Looking for some ideas on both problems. Thanks for reading n any advice would be appreciated. Thanks
ropinpete is offline
post #2 of 7 (permalink) Old 04-10-2014, 03:51 AM
2Dstorm's Avatar
Re: 2005 F350 6.0
It's could be a bad alternator, the ficm has to have a min. Of 10.5 volts to fire the injectors
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #3 of 7 (permalink) Old 04-10-2014, 12:53 PM Thread Starter
ropinpete's Avatar
Re: 2005 F350 6.0
That makes sense as to why it wouldn't fire. But shouldn't I have more than 1.7v on the green wire?
post #4 of 7 (permalink) Old 04-10-2014, 11:04 PM
09 6.4
webb06's Avatar
Re: 2005 F350 6.0
the alternator should be putting out 13+V to the batteries. the green wire you're talking about is on the plug going in to the alternator right?
2009 CCSB Black
6.4
12.6 @ 109 1/4 mile
webb06 is offline
post #5 of 7 (permalink) Old 04-11-2014, 01:11 AM Thread Starter
ropinpete's Avatar
Re: 2005 F350 6.0
Yes that's correct. The green wire is on the 2 wire plug going into alternator.
post #6 of 7 (permalink) Old 04-12-2014, 12:00 AM Thread Starter
ropinpete's Avatar
Re: 2005 F350 6.0
I was looking at truck again tonight and now the alternator is putting out 13.5 and there is 12 v on the green wire. I'm guessing that I have a bad connection or the instrument cluster is taking a crap. Any ideas? Guess I need to wait n see if/when alternator quits again.
post #7 of 7 (permalink) Old 04-29-2014, 12:37 PM Thread Starter
ropinpete's Avatar
Re: 2005 F350 6.0
Found out the alternator had a short internal. It finally acted up again. I did some checks sand found when I unplugged alternator that the green wire would jump up to 12v. Replaced alternator. Charging good tight now.
