05 hesitation - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 04-08-2014, 09:28 PM Thread Starter
05 hesitation
Hi guys, I have a hesitation under load with a boost fluctuation. I have cleaned egr valve and map hose/port. It has egr high flow code, unplugged egr valve and the truck runs better but still hesitates. there is no smoke and the truck is pretty much stock. Is this an egr issue? If I remove valve do I need to change the tune? also looking for a tuner in the future (after head studs). Any suggestions? thanks.
05 F250, 6Spd, 4" turbo back Magnaflow Duals, No cat. No muffler, Egr delete, Intake, SCT X4
bronco3512 is offline
