starting/dies - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-08-2014, 07:38 PM Thread Starter
Dprysta80's Avatar
starting/dies
06 f-250 FX4 with the 6.0, over the past few days I've been having problems starting it (go to turn key and nothing but I have full power, cycle key about 5 times and it will fire like nothing is wrong. Starting but keeps cranking and cranking (like its starving for fuel) and eventually dies or will turn over and just stall.) I had the batteries, starter and alternator tested and they all checked fine. I replaced the key switch but that didn't help with the key issue.
Now when I cycle the key the glow plug light stays on way long after the truck has been started.
Any suggestions?
Dprysta80 is offline
post #2 of 8 (permalink) Old 04-08-2014, 07:58 PM
jfarmer86's Avatar
Re: starting/dies
Have you checked the fuel psi or ficm volts?
jfarmer86 is offline
post #3 of 8 (permalink) Old 04-08-2014, 09:34 PM Thread Starter
Dprysta80's Avatar
Re: starting/dies
last time ficm was checked it was good. I don't remember the fuel psi
post #4 of 8 (permalink) Old 04-09-2014, 12:05 PM
jfarmer86's Avatar
Re: starting/dies
last time is not this time. You need to be able to monitor these things in order to diag.
post #5 of 8 (permalink) Old 04-09-2014, 11:35 PM
Re: starting/dies
Would def listen to this guy... I agree with the ficm
one day...
2006 silver f350 crew cab
5i1v3rback02 is offline
post #6 of 8 (permalink) Old 04-09-2014, 11:37 PM Thread Starter
Dprysta80's Avatar
Re: starting/dies
ficm and fuel psi checked ok. I replaced the starter (which was needing replaced) and I was getting codes for #2 and #5 injectors. My question is, is it worth to replace them all or just replace the bad ones? Also the ICP sensor (which has been replaced 3 times before) is acting up again, any suggestions for this issue?
post #7 of 8 (permalink) Old 04-10-2014, 11:32 AM
jfarmer86's Avatar
Re: starting/dies
I would change the 2 injectors not all 8 unless your wanting to go bigger
post #8 of 8 (permalink) Old 04-10-2014, 11:32 AM
jfarmer86's Avatar
Re: starting/dies
ICP if its still acting up, maybe you should change the pigtail
