05 6.0 rough idle at start up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-07-2014, 07:58 PM Thread Starter
05 6.0 with 57k miles. All stock except blue spring and 6.4 banjo bolts. Truck has recently started a rough idle issue. About 50% of the time it cranks and fires right off. The other 50% it will start and slowly climb to idle within 15-20 seconds. Haven't noticed a trend yet. It may happen after sitting over night or after only being shut off for an hour. Haven't had any issues with cold starts this winter. Any suggestions would be a help. Thanks.
7288ih is offline
post #2 of 7 (permalink) Old 04-07-2014, 09:34 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: 05 6.0 rough idle at start up
Most likely you have a injector stiction issue. There are some additives that claim to help, but the real fix is to replace the problem injector with a MOTORCRAFT injector.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #3 of 7 (permalink) Old 04-08-2014, 05:28 AM
At first I thought it was due to the temperature, but the problem has persisted into the summer. I noticed that I am having trouble producing boost for the first couple of miles. I just did the turbo cleaning procedure and while it was coked up, I am still having the same issues. I am not seeing any white smoke, just a rough idle and a seroius lack of power for the first couple of miles. I am at a lost!!!
Stephen Heath is offline
post #4 of 7 (permalink) Old 04-08-2014, 06:04 AM
2Dstorm's Avatar
Try archoil ar9100 or rev x on a fresh oil change just might work. Sounds like stiction.
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #5 of 7 (permalink) Old 04-08-2014, 06:56 AM
You should be getting a code. Do you have a reader to check for codes? The Check Engine Light will not always come on.
superchaos is offline
post #6 of 7 (permalink) Old 04-08-2014, 03:18 PM
2Dstorm's Avatar
Bad injectors don't always pull codes. You need to run a contribution test. It will pen point which injectors are giving you problems. If it were me I would replace all the injectors if you find a couple running low contribution..the rest if if them are on the way out especially if it's a stiction issue.
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Volant intake
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #7 of 7 (permalink) Old 04-09-2014, 10:41 PM
Your turbo wont spool like it should because your injectors arent firing or firing right, with no combustion no heat and turbos need heat
one day...
2006 silver f350 crew cab
5i1v3rback02 is offline
