Newbie Needs Help-03 no start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-06-2014, 04:39 PM Thread Starter
I am new to powerstrokes. Just got done with new oil cooler, studs, oem headgaskets, new hpop. I got it all reassembled and it ran for ten minutes and died with rpms a little above idle. Got a scangauge 2 and have FICM volts over 47 at all times, ficm is synced, but ipr goes to 85% and icp wont go above 300-350. What next?? I am ready to throw in the towel and have it towed to the shop;after all this work though I would like to finish the job! Thanks in advance
2003 PS 6.0 with 180000
jeremyshanemoore is offline
post #2 of 8 (permalink) Old 04-06-2014, 05:31 PM Thread Starter
Re: Newbie Needs Help-03 no start
I unplugged the icp to see if it will start(saw on forum to try) and still didn't start. The ipr reading then was 1895 and icp was 56.
post #3 of 8 (permalink) Old 04-07-2014, 02:57 AM
Big dumb redneck
6speedSD's Avatar
Garage
That sounds like a HPOP problem, but you said you just put a new one on it. Not sure if air in the system would cause those numbers or not though. Motorcraft HPOP?
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #4 of 8 (permalink) Old 04-07-2014, 03:10 AM Thread Starter
Bosch.....I am hoping this is an easy fix without having to tear back down. I realized that I have an aftermarket(tall) oil filter cap with a new oem oil filter. I have read that causes no starts so I am hoping that's it. I will get a new cap tomorrow.
post #5 of 8 (permalink) Old 04-07-2014, 03:17 AM
Big dumb redneck
6speedSD's Avatar
Garage
That's a start. Get rid of that thing and get a stock cap and Motorcraft filter. ONLY use Motorcraft (or Racor) filters on a 6.0!
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #6 of 8 (permalink) Old 04-11-2014, 01:43 AM Thread Starter
Guys thanks for all your help....I got my ipr socket in the mail and pulled it out tonight. The screen was covered in a fuzz like substance. Cleaned the screen off, reinstalled and she fired right back up. THANKS for everyones help!!! Now to put it all back together!
post #7 of 8 (permalink) Old 04-12-2014, 01:42 PM
Skiddy's Avatar
I had the same problem. Replaced the oil cooler and it ran for two days and then a no start. Pulled the ipr and bit had a big hole in the screen. You have to be sterile when working below all your filters.
Skiddy is offline
post #8 of 8 (permalink) Old 04-13-2014, 03:17 AM
Big dumb redneck
6speedSD's Avatar
Garage
By chance did you clean around your oil cooler with some cotton rags? You said white fuzz....sounds like some lint from whatever you cleaned it with. The reservoir has to be absolutely clean when you put it all back together.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
