Chasing a no start condition! Help! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-05-2014, 09:17 PM Thread Starter
IIvonnyII's Avatar
Hey everyone, buddy of mine has an '03 f350 6.0/6spd and it's not starting.
He has new ipr valve icp sensor, brand new injectors, he's getting fuel to the bowl, ficm just repaired by Ed @ficmrepair , truck turns over and just doesn't want to fire.. He's been working on it for a long time and is out of ideas.. Anyone have anything to check? Thanks
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
post #2 of 10 (permalink) Old 04-05-2014, 09:22 PM Thread Starter
IIvonnyII's Avatar
Re: Chasing a no start condition! Help!
Y pipe, egr delete, hpop , oil cooler, injector o rings, turbo rebuild.. Has 2000k on everything except ficm
Admin of BCCR
- 205/100s
- BW S366
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
post #3 of 10 (permalink) Old 04-05-2014, 10:04 PM Thread Starter
IIvonnyII's Avatar
P0232 fuel pump secondary circuit high is the only code
Admin of BCCR
- 205/100s
- BW S366
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
post #4 of 10 (permalink) Old 04-06-2014, 02:20 AM
Fixing Broken Stuff
toolmangary's Avatar
Check ICP, FICM voltage, fuel pressure, and see if it has sync. If somebody just did the injectors and didn't get them torqued correctly the compression will go by the copper washer and aerate the fuel system. That is usually caused by not blowing the oil out of the injector hold down bolt hole. I'll bet I've seen that mistake at least a dozen times by now.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #5 of 10 (permalink) Old 04-06-2014, 08:42 AM Thread Starter
IIvonnyII's Avatar
Ficm voltage is perfect, it has sync also, icp voltage also checked out. It be injectors, but he did have them professionally done.. But I guess they could obviously have made a mistake .. But he ran 2000kms on the new injectors, ever since the ficm died it hasn't ran.
post #6 of 10 (permalink) Old 04-07-2014, 04:01 AM
Big dumb redneck
6speedSD's Avatar
Garage
So after all that work, it ran fine, but started the no crank issue after the FICM died?
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #7 of 10 (permalink) Old 04-07-2014, 04:19 AM
97F250TD's Avatar
Hate to be a smart ass but are all the plugs on the ficm plugged in all the way? I no I've ran into issues with them before!
1997 F250 6" lift 37" nittos hypermax intercooler and stage 1 injectors built bts tranny D60 front dp tunes triple a-pillar gauges sky rsk front w/v code springs 240k miles
97F250TD is offline
post #8 of 10 (permalink) Old 04-09-2014, 11:58 PM
You said you have a p0232 thats your problem your fuel pump is not running... listen under the truck when you turn the koeo your should hear the pump if you dont check for power and ground and load test the circuit with a lightbulb im wiling to bet your pump is just bad though
one day...
2006 silver f350 crew cab
5i1v3rback02 is offline
post #9 of 10 (permalink) Old 04-10-2014, 12:43 AM Thread Starter
IIvonnyII's Avatar
The plugs are in all the way , and yes worked perfect until the ficm died . And the fuel pump isn't making a sound
Admin of BCCR
- 205/100s
- BW S366
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
post #10 of 10 (permalink) Old 04-10-2014, 02:58 AM
Fixing Broken Stuff
See if you have 12 volts on the pump, if not it is most likely the fuel pump relay. On a 03 you won't find the relay because it's integrated in the fuse panel
and is not serviceable, you'll have to change the fuse panel.
2004 Jetta TDI
1956 F100
