power then no power - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 04-03-2014, 07:42 PM Thread Starter
power then no power
How is everyone doing today. I am at a stump right now with my truck. At times it feels like the truck is balls out quick then at times it feels like a fat pig trying to move out of its own way. List of what is done is in my sig. please help me out guys.
Murdered6.0 is offline
post #2 of 15 (permalink) Old 04-04-2014, 10:48 AM Thread Starter
Re: power then no power
not one person on this site that has viewed this can help me out
2004 4door long bed 6.0 upgraded standpipes and dummys, blue spring, new heads, studs, egr delete, uppipes, brp street runner tune, 37" tires, stock trans, scangauge, egt, boost, trans temp
post #3 of 15 (permalink) Old 04-04-2014, 12:52 PM
JGman141
Jgman141's Avatar
Anything wired with your egts or vgt duty cycle?
Jgman141 is offline
post #4 of 15 (permalink) Old 04-04-2014, 12:54 PM
jfarmer86's Avatar
Whats your ICP and EBP reading? Also whats your boost hitting at?
jfarmer86 is offline
post #5 of 15 (permalink) Old 04-04-2014, 03:58 PM Thread Starter
I am hitting around 28 pounds of boost ebp is 50-51 icp 800 ipr duty is 81% have not check vgt duty cycle yet. these reading are at full throttle. cruising at 60 mph im seeing 30% ipr 1000 icp 22 22 ebp about 5 pounds boost. I have a lot of exhaust flutter wen letting off the throttle. I have a new turbo going in today after work to see if that helps
post #6 of 15 (permalink) Old 04-04-2014, 06:08 PM
jfarmer86's Avatar
Is the ICP voltage speratic? At idle it shouldn't just around to much or if its low that could be a source of your issue
post #7 of 15 (permalink) Old 04-04-2014, 09:27 PM Thread Starter
ok heres a update at idle vgt is 64 ebp 17.2 ipr 22.2 icp 583 this is at idle . icp moves around between 580 and 590 everything else is steady. cruising at 60 mph evertything is the same at before but vgt is 44
post #8 of 15 (permalink) Old 04-05-2014, 01:29 AM
Fixing Broken Stuff
toolmangary's Avatar
What is your EBP voltage KOEO & KOER?
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #9 of 15 (permalink) Old 04-05-2014, 12:04 PM Thread Starter
I will be doing all of the tests I can do with my snap on modus today after work
post #10 of 15 (permalink) Old 04-12-2014, 02:51 AM
Have you figured out your problem?Mine is doing the same thing. Sometimes it doesn't rev over 3k and the factory boost gauge won't move.
GOT TRQ is offline
