Ok I'm stumped - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-03-2014, 06:40 PM Thread Starter
The Red Devil
THE RED ROCKET's Avatar
Send a message via AIM to THE RED ROCKET Send a message via Skype™ to THE RED ROCKET
Ok I'm stumped
Ok so I have a 2005 f350 6.0 and my CEL is on I found codes for injectors p0261-p0268 put I have check everything from FICM to the Injectors them self truck runs great help ?
THE RED ROCKET is offline
post #2 of 12 (permalink) Old 04-03-2014, 07:56 PM
jfarmer86's Avatar
Re: Ok I'm stumped
If all 8 injectors are reading bad your ficm is shorting out
jfarmer86 is offline
post #3 of 12 (permalink) Old 04-03-2014, 07:56 PM
jfarmer86's Avatar
Re: Ok I'm stumped
Or a harness issue
post #4 of 12 (permalink) Old 04-03-2014, 08:26 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: Ok I'm stumped
So how does it run? Does it have 2 codes? or everything between those 2 codes?
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #5 of 12 (permalink) Old 04-03-2014, 09:15 PM Thread Starter
The Red Devil
Re: Ok I'm stumped
It runs great and has all codes between the 2 and I have replaced the harnesses and FICM alls had ford test the injectors so I'm lost on this I work in shop in ct so I work on it daily but It just has me stumped as to what it could be
05 F-350 XLT. AEM workhorse, EGR delete kit, air dog II, 6 inch stacks with 3.5 inch down pipe , 37 inch nitto terra grapplers, procomp 8089 , 8 inch procomp ,procomp dual SS ,sct extreme,
99 F-350 XLT, Work truck stock
03 F-350 Lariat, Banks turbo upgrade, 5 inch turbo back, banks chip
post #6 of 12 (permalink) Old 04-03-2014, 09:47 PM
Fixing Broken Stuff
Re: Ok I'm stumped
So the only thing left is the injectors. The reason you have a CEL is because the PCM is picking some misfires, I'd say probably caused by stiction when it's started cold. I use a Hickok G2 tester for testing for stiction, I can start a engine cold and in less than a minute know exactly which injectors are the problem. I have seen them with all eight bad then after a minute of run time some injectors start to clear up, some take longer, some don't clear up at all.
I think the only way the dealer tests the injectors for stiction is with a cylinder balance test, the Hickok blows that away, check the vid's for it on u-tube.
2004 Jetta TDI
1956 F100
post #7 of 12 (permalink) Old 04-03-2014, 10:30 PM Thread Starter
The Red Devil
Re: Ok I'm stumped
Just had my injectors rebuild/cleaned so I'm a assuming not injectors
post #8 of 12 (permalink) Old 04-04-2014, 02:38 AM
matthewd11's Avatar
Re: Ok I'm stumped
If all that is truly new you must have a bad connection at the ficm.
matthewd11 is offline
post #9 of 12 (permalink) Old 04-04-2014, 03:13 AM Thread Starter
The Red Devil
Re: Ok I'm stumped
yea i guess ill be the new plug ends and see if that help im wondering if it can be in the PCM.
post #10 of 12 (permalink) Old 04-04-2014, 07:33 PM
Fixing Broken Stuff
Re: Ok I'm stumped
Who did the injectors?
2004 Jetta TDI
1956 F100
