BYPASS OIL SYSTEMS - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 04-02-2014, 04:37 PM Thread Starter
BYPASS OIL SYSTEMS
What bypass oil system do you have, what do you like, what do you hate, what would you change?
I have the Racor 802 and love the system. I like that it filters down to 1 micron and it adds 2.5 quarts of oil to the system. I hate that filters used to cost $7.00 and are now over $30.00. I have only 6 filters left and I am thinking of building a centrifuge system.
lenzhotrod is offline
post #2 of 11 (permalink) Old 04-02-2014, 05:30 PM
matthewd11's Avatar
Re: BYPASS OIL SYSTEMS
How to do you keep the oil from shearing to a 30 weight with a bypass (assuming you are running extended OCI)? Are you using a 10w-30 oil?
matthewd11 is offline
post #3 of 11 (permalink) Old 04-02-2014, 07:09 PM Thread Starter
No extended oil changes for me. At 5,000 miles I change the oil and engine filter. I change the bypass every fourth oil change. My oil usually is as clean when I drain it as it is when I put it in.
post #4 of 11 (permalink) Old 04-03-2014, 12:23 AM
PursuitInterceptor
HeavyAssault's Avatar
Oil shear is due to mechanical processes not how well it has been filtered. My research showed the Amzoil EaBP100 filter was the best option. Filters down to 1-2 micron, with reports it's good for 60k miles. I bought a kit that allowed a oil bypass and coolant filter on the same bracket. I don't like the overall cost but it's cheap insurance. I've used a different brand bypass years ago and switched cause of finding the filters and reducing costs. My truck has 277k on the original injectors so it's helping I'm sure. I run 7500 mile intervals and try to never exceed 10k. I ran 5w40 synthetics till a few months ago. I have now switched to Mobil 1 10w30 blended to "proof the pudding". So far it's doing just fine!!
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #5 of 11 (permalink) Old 04-03-2014, 01:38 AM
matthewd11's Avatar
I know what shear is that is why i asked about the bypass as filtration wont fix shearing. It just doesnt seem really cost effective IMO. But the 1-2 micron particle filtration is a big bonus (although overkill)
post #6 of 11 (permalink) Old 04-03-2014, 01:49 AM
03 King Ranch DRW's Avatar
I have the Amsoil kit. Running it for about 8 years with no issues. Filters could be a little cheaper. But can't have everything.
03 King Ranch DRW is offline
post #7 of 11 (permalink) Old 04-03-2014, 02:36 AM
'05 Excursion
Term3's Avatar
I looked into an oil centrifuges and decided against it due to the higher minimum flow rate needed, they don't work until your oil is up to operating temperature, need a 1" drain line with no sharp bends or you can get the one that uses an air pump to help carry the oil away, which is just one more thing to screw up. A 1 or 2 micron filter can be mount absolutely anywhere, has no moving parts to wear out (the centrifuge spins at a few thousand RPM), you know it's still working because its still hot to touch. Centrifuges work GREAT for large engines like over the road diesels or diesels that run day after day. For our trucks half the time they don't spin anything out.
Sent from AutoGuide.com App
Term3 is offline
post #8 of 11 (permalink) Old 04-03-2014, 01:22 PM Thread Starter
The centrifuge system I am looking into does 55 gallons per hour and needs the same flow as I currently use on the Raycor. The upside is no filters to buy. The downside is I have to mount it above the valve cover to flow oil back to the engine. I like that my Raycor is mounted under my truck and unseen.
post #9 of 11 (permalink) Old 04-03-2014, 03:39 PM
Wheelhop's Avatar
Where can a guy get the 6 foot long braided hoses to remote the filter to the frame?
I like the Amsoil setup, but I want the filter out of the engine compartment and the ones in the kit are too damn short.
Anyone know?
Wheelhop is offline
post #10 of 11 (permalink) Old 04-03-2014, 05:01 PM Thread Starter
Summit Racing for hose or fittings.
