buy at your own risk - PowerStrokeNation : Ford Powerstroke Diesel Forum
Closed Thread
post #1 of 11 (permalink) Old 04-02-2014, 04:51 AM Thread Starter
Thought I would save some money, and bought dorman oil cooler. $200 and lifetime warranty.. stock coolers plug and with a life time warranty, figured why not. Jobs not really all that difficult, and figured it would last a couple years anyways.... 3 coolers later in the last year, and I've had it with dorman. The bottom of the oil cooler housing dorman gives you in their kit, swells and deteriorates when oil comes in contact with it. I called dorman and they finally admitted they have had issues with that gasket. They also admitted to getting rid of some of the surface area too cut back cost. These coolers fail internally. also once that gasket and breaks apart, it makes a huge mess in the hpop reservoir. Which in my cause has plugged my ipr valve. Wouldn't suggest anything but oem, Buy at your own risk.
bunique09 is offline
post #2 of 11 (permalink) Old 04-02-2014, 10:54 AM
PursuitInterceptor
HeavyAssault's Avatar
Re: buy at your own risk
Sorry to say thanks for helping out the next guy. I hope it's all OEM at this point.
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #3 of 11 (permalink) Old 04-02-2014, 12:38 PM
Fixing Broken Stuff
toolmangary's Avatar
The only aftermarket parts that I think are safe for a 6.0 are ARP studs and a EGR delete kit, everything else needs to be OEM.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #4 of 11 (permalink) Old 04-07-2014, 08:31 PM
Banned
We have resolved the issue with the Gasket being made of the wrong material and coming a part in the high pressure oil system. As far as the cooler itself there is no issues. We have had customers say it cools better then the OE.
Dorman Diesel is offline
post #5 of 11 (permalink) Old 04-07-2014, 08:40 PM
there are ZERO things from dorman that are ok to buy. Its the crappiest of the crap parts out there. actually..i have door pins in my truck that are from dorman. they are ugly as sin but they work. other than that, ill never buy dorman stuff
95 f250 ECLB,silver/purple 199k FFD 350/200s, arps, comp 910 shimmed, BTS ZF delete, glowshift EGT,Boost,trans temp,6" aussies,6637, 6.oh IC,dual sd elec fuel. irate T4, S475/96,136k 97 motor. Twin termies
Plans: twin turbs, crowers and fresh rebuild.
rideracelivemx7 is offline
post #6 of 11 (permalink) Old 04-07-2014, 08:42 PM
Fixing Broken Stuff
That oil cooler gasket issue caused a lot of people a lot of problems. It cost the tow bill, labor, replace the oil cooler with a OEM, some had to replace their IPR, oil, anti-freeze.
So what does Dorman plan to do for their customers that bought your oil cooler for the 6.0 Powerstroke and had to replace it?
Also how does your oil cooler cool better than the OEM? I'd sure like to know.
2004 Jetta TDI
1956 F100
post #7 of 11 (permalink) Old 04-07-2014, 09:36 PM
Big dumb redneck
6speedSD's Avatar
Garage
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #8 of 11 (permalink) Old 04-07-2014, 09:47 PM
Fixing Broken Stuff
^^^ Yep, with butter please, I told the wife to pick up some more, were gonna need it
2004 Jetta TDI
1956 F100
post #9 of 11 (permalink) Old 04-07-2014, 10:07 PM
Yea I would be willing to bet they don't respond...
a2elvis is offline
post #10 of 11 (permalink) Old 04-07-2014, 10:13 PM
Big dumb redneck
6speedSD's Avatar
Garage
Yea, I'll probably have to agree. But maybe they will. I'm in.... this should get good.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
Closed Thread
