Front passenger window problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 04-02-2014, 02:08 AM Thread Starter
Wyo
scouts out...
Wyo's Avatar
So went out to feed the horse today, rolled down the driver window and passenger window. Went to roll them up and only the driver window went back up. I don't know too much about this part of my truck, I tried the switch on the passenger side and same thing. All other windows function fine, but the passenger one won't roll up with either the switch on the driver side or the switch on the passenger side. I noticed that even though it's all the way down if I push the button down the motor does draw current and attempt to go down, up is completely dead no sound what so ever. Anyone have any ideas?
2007 CC, Lariat, 6.0L, TreadWright guard dogs, straight piped out the back, egr delete, blue spring, 6.4 banjo bolts, high idle mod(bcp), bulletproofed, SCT Livewire TS with Drews street runner(under development for high elevation), Innovative, and Vivian's tunes, ww2.
Wyo is offline
post #2 of 9 (permalink) Old 04-02-2014, 09:01 AM Thread Starter
Wyo
scouts out...
Wyo's Avatar
Re: Front passenger window problems
Anybody have anything?
Wyo is offline
post #3 of 9 (permalink) Old 04-02-2014, 01:14 PM
I had this happen to my truck. Turned out to be the driver side controls, replaced unit problem fixed.
LVK9 is offline
post #4 of 9 (permalink) Old 04-02-2014, 04:32 PM Thread Starter
Wyo
scouts out...
Wyo's Avatar
so just that switch on the drivers side, is what you're thinking? If that's the case then I would have to guess that the two switches(driver and pass) are linked somehow.
Wyo is offline
post #5 of 9 (permalink) Old 04-02-2014, 08:16 PM
Happened a few years back, they replaced the entire assembly on the drivers door?
LVK9 is offline
post #6 of 9 (permalink) Old 04-02-2014, 09:12 PM Thread Starter
Wyo
scouts out...
Wyo's Avatar
well maybe I can get away with just the switch. lets hope
Wyo is offline
post #7 of 9 (permalink) Old 04-02-2014, 10:39 PM
Jackleg Mechanic
mastrkee's Avatar
I would try to get a hot wire to the motor or at least to the PS switch and make sure the motor would roll it up.
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #8 of 9 (permalink) Old 04-03-2014, 01:26 AM Thread Starter
Wyo
scouts out...
Wyo's Avatar
Is there a good 12v source close to that motor?
Wyo is offline
post #9 of 9 (permalink) Old 04-03-2014, 02:17 AM Thread Starter
Wyo
scouts out...
Wyo's Avatar
Ran a lead from that battery to the motor and got nothing. Looks like I need a motor. Thanks for all the help guys
Wyo is offline
