Fuel smell - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-31-2014, 10:34 PM Thread Starter
Fuel smell
So i have had my truck for about 3 months now and recently started smelling fuel through the vents when my heat or a/c was on. Well today me and a buddy were looking underneath the truck and seen there was some fuel leaking on the back of the motor. Im new to the diesel scene, and he through out a couple things that could be wrong. But was wondering what anyones ideas might be and what it might cost. Thanks
05Powerstroke1121 is offline
post #2 of 10 (permalink) Old 03-31-2014, 11:26 PM
2Dstorm's Avatar
Re: Fuel smell
Back side is most likely a set of banjo bolts maybe a cracked line
If you replace the banjos use 6.4 bolts and washers they seal up better
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #3 of 10 (permalink) Old 03-31-2014, 11:32 PM Thread Starter
Re: Fuel smell
Buddy said it was the driver side head, we are going to get a small mirror and give it another look tomorrow to see if we can pinpoint it
post #4 of 10 (permalink) Old 04-01-2014, 12:31 AM
Re: Fuel smell
arent the fuel lines in the front of the head, thats where i remember them being if its not the fuel lines its mostly likely a oring plug for the fuel galley.
polish pete is offline
post #5 of 10 (permalink) Old 04-04-2014, 07:06 AM
2Dstorm's Avatar
Re: Fuel smell
The return lines are on the back side
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Volant intake
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #6 of 10 (permalink) Old 04-06-2014, 10:30 PM Thread Starter
Re: Fuel smell
I had another guy say that is could be the return lines, going to take a look tomorrow
post #7 of 10 (permalink) Old 04-06-2014, 10:46 PM
Re: Fuel smell
I had bad fuel smell inside the cab as well that I just fixed. It was the flex part on the y-pipe. Seems to be a common issue on these trucks
2007 Ford F250 CCSB - Daily Driver
KC Turbo, WPE Manifold, Fuel System, Exhaust, Studded, Deleted.
670RWHP / 1153RWTQ-Fuel Only
2000 Ford Lightning SVT - Weekend Toy
Built Motor, Whipple , Heads, Cams, Fuel System, Exhaust, Suspension, Full interior with AC
10.9 @ 124mph on 18" DR's on Pump Gas
ZaC851 is offline
post #8 of 10 (permalink) Old 04-10-2014, 03:13 AM
Fixing Broken Stuff
toolmangary's Avatar
Re: Fuel smell
Actually the return line is on the fuel bowl, the fuel supply line connects to the front of each cylinder head, there are no lines on the rear of a 6.0 cylinder head.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #9 of 10 (permalink) Old 04-11-2014, 03:24 AM
'05 Excursion
Term3's Avatar
Re: Fuel smell
But there are plugs at the rear of the heads that seal off the fuel header b
Sent from AutoGuide.com App
Term3 is offline
post #10 of 10 (permalink) Old 04-16-2014, 02:08 AM
Re: Fuel smell
Also check exhaust manifold as these did not come from factory with gaskets just close machine tolerance.
Deuce02 is offline
