coolant pressure problem? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-29-2014, 06:33 PM Thread Starter
DSGDB6.0
Ok guys so my new rig is 06 f250 mods are coolant filter, 03 turbo, arp studs ,egr delete ,and sct live wire..i bought the truck it needed a turbo so i babied it with no tune until 03 was installed I'm running sct on extreme street and degas bottle has been puking since .. also oil cooler is brand new my eot and ect are in check and normally only vary by around 5 degrees . truck is egr deleted so i know thats not the problem i hooked up a coolant pressure gauge once truck is warm it will rise to around 8-10 lbs and under wot it slowly climbs to 12-14psi yet it still pukes i just put a new cap on still puking maybe i should try another cap maybe my pressure gauge is off idk its all brand new i hope its not hg's however thats what I'm leaning towards any help or advice would be great thanks
2006 F250 zf6 :) ccsb 6.0l Fx4 ,egr delete,Studded, coolant filter,live wire ,,Blue spring,innovative tunes,Warren 190/75 ,s&b.
PARTED OUT 2004 F250 ccsb 6.0l Fx4 -O ringed ,egr delete,Studded, coolant filter,Sct live wire ,Afe drop in,Blue spring,6.4 banjos,4inch turbo back duals,warren 205cc/100cc, fuel system under construction.
DSGDB6.0 is offline
post #2 of 7 (permalink) Old 03-29-2014, 07:13 PM
"Slap hands slap hands"
FlossyB's Avatar
Re: coolant pressure problem?
I would take the tune off and return to stock or run the tow tune and see if it continues to do the same thing. also I would buy a new cap just to double check. good that you EOTs and ECTs are where they need to be.
JB
FlossyB is offline
post #3 of 7 (permalink) Old 03-29-2014, 07:38 PM Thread Starter
DSGDB6.0
FlossyB thank for response if i return to stock and baby it truck won't puke but i deff wanna run my tuner. I'm working on getting this thing diagnosed today incase i need to get her in the garage and pull the cab off tonight . any help would be greatly appreciated.
DSGDB6.0 is offline
post #4 of 7 (permalink) Old 03-30-2014, 03:22 AM
Big dumb redneck
6speedSD's Avatar
Garage
If its not building over 12-13psi at WOT, I wouldn't think it's HG's. But, I'm no expert.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #5 of 7 (permalink) Old 03-30-2014, 04:42 PM Thread Starter
DSGDB6.0
I agree with you 6speedSD thats what I'm hoping for but I'm not quite sure were else to point my fingers. but what concerns me is it stays around 9-11psi no matter what once up to operating temp. also if my gauge is reading 12 psi at maximum why is the cap puking gonna pick up another cap a the dealer tomorrow.
DSGDB6.0 is offline
post #6 of 7 (permalink) Old 03-30-2014, 04:57 PM
Fixing Broken Stuff
toolmangary's Avatar
How was the surface of the heads and deck prepped when the HG's were done?
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #7 of 7 (permalink) Old 03-30-2014, 06:50 PM
Big dumb redneck
6speedSD's Avatar
Garage
I'd start with a new cap for sure. Too many parts these days are bad right out of the box.
I'd also make sure your degas tank doesn't have a crack somewhere. If it does, it could vent some of the pressure under a load and give you a false reading on your gauge. These tanks are prone to cracking.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
