APP voltages - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-28-2014, 11:15 PM Thread Starter
Big dumb redneck
6speedSD's Avatar
Garage
APP voltages
Would someone have access to voltage readings on the accelerator pedal assembly at random pedal positions? I know what spec is for closed and WOT positions, but I'm curious about the readings in between for APP's 1, 2, and 3. Mainly something like this....
voltage for App 1 at 10% pedal position
app 2 at 10%
app 3 at 10%
App 1 at 20%
etc
etc
Is it listed in the manual in something like 10% increments for each APP, or would someone already have some info like this already?
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #2 of 7 (permalink) Old 04-03-2014, 01:18 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: APP voltages
Are you having a problem? I can check one for you in a little bit.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #3 of 7 (permalink) Old 04-03-2014, 02:48 PM Thread Starter
Big dumb redneck
6speedSD's Avatar
Garage
Re: APP voltages
Nah, I replaced the pedal assembly already. Thanks though.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #4 of 7 (permalink) Old 04-03-2014, 03:06 PM
Fixing Broken Stuff
Re: APP voltages
Was your pedal going dead??
2004 Jetta TDI
1956 F100
post #5 of 7 (permalink) Old 04-03-2014, 05:04 PM Thread Starter
Big dumb redneck
6speedSD's Avatar
Garage
Re: APP voltages
No sir... had some shifting issues. Thought maybe I had a spot at part throttle that wasn't measuring accurately. Turns out that wasn't the case. Oh well, I got a good deal on it, so I'm not out too much.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #6 of 7 (permalink) Old 04-03-2014, 05:23 PM
Fixing Broken Stuff
Re: APP voltages
I've seen some 7.3's with a bad pedal and I couldn't see the problem with a DVO meter, I even tried to graft it and couldn't see the glitch, but a new pedal was the fix. They would randomly just idle.
So was the trans your problem?
2004 Jetta TDI
1956 F100
post #7 of 7 (permalink) Old 04-03-2014, 07:14 PM Thread Starter
Big dumb redneck
6speedSD's Avatar
Garage
Re: APP voltages
Don't think so. Shift timing has just been off, and some shifts get pretty harsh as well. Happens worse as you increase pedal position. That's what made me think I was getting inaccurate readings at part throttle. Lately I've developed a laggy, slow to build boost situation. Think that's part of the problem. Just haven't had time to figure out what's causing it yet. Working too many hours here lately doesn't leave much time to diagnose problems!
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
